Question about Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
Samsung flatscreen has no sound
My tv has sound when I play a DVD but not when I have the cable on - it was working fine and I did something, don't know what? pls help!
  • 1 more comment
  • pengoda Jul 19, 2008
    I am having the exact same problem.
  • luannec Sep 08, 2008
    I have no sound on my Samsung CXM2785 combo tv also.  I don't think I did anything to cause it because it was working fine and then the next time I turned it on, there was no sound.  I've looked around in the menu to see if there was something that looked odd but I couldn't find anything wrong.  This TV is a few years old but hasn't been used that much.
  • luannec Sep 10, 2008
    I am also having this problem. I contacted Samsung twice and have gotten no response. I had not changed any of the settings, just turned it on one day and there was no sound. I tried with a DVD and the sound is find so it's just when it's in TV mode.
I had the same problem and I finally got in touch with Samsung and they told me that it must be something with the satellite receiver or Tivo box I have connected to the TV, since the sound was working in DVD mode.  I reset both DirecTV receiver and Tivo box and now the sound is working again.  I guess I should have done them one at a time so I'd know which one caused the problem.  But, give it a try, it might work for you, too.
Posted on Sep 10, 2008
    New Friend:
I have sound but no picture!!!!!!!!!!!!!!!
Posted on Jan 29, 2013
Need help connecting a funai dv220fx4 to a vizio m470vse?
Sounds to me like you got the component leads correct but not the composite (video).
See in the link for downloading the manual :-)
Funai 50 years of Excellence in Consumer Electronics
Apr 23, 2014 | Vizio L37 Television
If you have a scart socket on the TV it would be much easier to use this
Sep 12, 2017 | Vizio L37 Television
Hdmi compatibility
Hello, how long is the cable from the receiver to the TV? Thank you, Onkyo USA
May 31, 2017 | Onkyo TX-SR706 Receiver
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
My vizio flatscreen lcd has pic but will not play sound through the tv output, however it will pay sound when watching a dvd - just not when watching satellite
Use the cables connecting the DVD and connect the satelite.
If everything works OK, then check and replace the cables for the Satellite.
If the sound is still No Good, check the audio settings on the satellite
You may connect the DVD using the Satellite cables as a check as well
Jun 05, 2009 | Televison & Video
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
Connecting a Samsung DVD 871M to Samsung hd ready flatscreen tv via hdmi cable. Cannot seem to go past the set up section.
look on your remote control normally you have a button named
"av output" are something like that press it a couple time to have the good screen output
Nov 29, 2008 | Televison & Video
Blue tent while playing movie
what type cables are hooked to the dvd, check and make sure that the cables are seated properly or chang the cables , could be the dvd player also
Feb 16, 2008 | Samsung LN-T4671F 46 in. LCD Television
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Jan 21, 2008 | Samsung DVD-HD950 DVD Player
Samsung CXM2785TP 27 in. TV/VCR/DVD Combo Logo
1,830 people viewed this question
Henry  Thomas
Henry Thomas
