Question about Panasonic KX-T7730 Corded Phone
Panasonic KXT 824 BX and KXT 7730 Handsets
Hi I've got the above system and handsets, literally 3 lines and 3 handsets!
However I've noticed that the phones/systems/ or lines aren't always consistent, when we are called by a customer everything works perfectly but for some reason they cannot always hear us clearly, it sounds very faint... I'm wondering if you've come across this problem before? Also is there a way to turn up the microphone on the handset so they can hear us better?
please help!! shanh@bthell.com
5 Suggested Answers
SOURCE: Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Posted on Jan 21, 2007
SOURCE: VT 2461 Won't let me register new handset
Rosehello's solution worked with one additional step for my handsets...After re-programming all of the 4 handsets, I had to unplug the base unit one more time and then it reset. Until that time it would only show"AL" and would not function.
Posted on Jan 25, 2008
  • 518 Answers
SOURCE: unable to register handsets to
From the manual:
1) Before registering the extra handset, the battery pack MUST be charged for 15-20
hours.
2) With the main base in standby mode, press the MENU soft key on the base.
3) Press /vol/∧ or /vol/∨ on the base to select H S R e g i s t r a t i o n, and then
press the OK soft key.
4) On the handset, press and hold # for two seconds. To cancel registration, press
the CANCEL soft key on the base.
5) While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the Handset
LCD. When R e g i s t r a t i o n C o m p l e t e is displayed, the handset has been registered
to the base. If R e g i s t r a t i o n F a i l e d appears, please try these steps again.
Geno
Posted on Mar 05, 2008
bbtoast
  • 319 Answers
SOURCE: Extra handsets no longer seem to work. No ring and no line
Please be sure to put the extra handsets in the MAIN base station to register. They will not register in the small remote charger stations.
Let me know if that fixes the problem!
Brian
Posted on Jun 17, 2008
  • 79 Answers
SOURCE: how to use intercom between two handsets
For models with 2 or more
handsets included
Making an intercom call
1 Press {INTERCOM}
2 To page the base unit, press {0}.
To page another handset, enter its
extension number ({1} – {4}).
The destination unit beeps for up to 1
minute. Someone else can answer the other unit and talk to you.
3 To end the intercom call, press {OFF}.
Posted on Aug 24, 2008
KX-TGA660 handsets - 3 of 5 wouldn't ring (no sound)
sounds like who ever installed your service was an amateur, all points should be gone over by a senior tech, piece by piece!!
Nov 14, 2013 | Panasonic Lands Phones
Our office pabx is a Panasonic KX-TA616. I am trying to program personal speed dial on a Panasonic KX-T7730 (which has 12 CO buttons on the right but no Personal Feature buttons). Neither of the...
Look carefully at the part number on the phone and where you posted. A Panasonic 7730 set has 24 buttons, 12 left side C.O. buttons and 12 right side PF buttons. A TA30830 (new style) has 12 buttons with LED's. In our country, the TA30830 needed 824 version 2 or greater software to work.
In your country the other mate to that is the KXT-7667.
If your phone is one of those and actually works, as in any Panasonic set, the LED buttoon requires a "2" in front of the digit sequence to tell the system it's a PF button.. So, PROG button 2+access code+number STORE saves a speed dial. The access code is what you dial to get an outside line.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
How do i program the panasonic kxt-7731 so when a call is coming in i can just lift the handset to answer instead of pushing the co line
You have to do 2 things: Make it ring and turn on Line Preference-Incoming Ringing line. The first is done from SYSTEM programming in programs 408/409/410 for DAY/NIGHT/LUNCH. The second is defaulted to Ringing so if the phone rings, it's supposed to work. If you've changed it, then from your idle phone you press PROGRAM and dial 22 STORE. (21 is no preference and 23 plus a number is a specific line).
Carl
Apr 26, 2011 | Panasonic KX-T7731 Corded Phone
I just bought my panasonic units and i cant change the date model number of the phones kxt-7730 hybrid system tes-824 i want to change the date i have tried program 0 but it doesn't work i get the 3 beeps...
Since that's done from SYSTEM program 000, it seems likely that you 1. Aren't using extension 101 and 2. Didn't log into the system for programming
Try it again.
Carl
Apr 20, 2011 | Panasonic KX-T7730 Corded Phone
I have panasonic phone kx-t7730 i want add one more line plz help
Since a 7730 is just a phone, you need a bit more information. It plugs into a Pana KSU, typically a TA 624/824 for that model era. A TA starts as a 308 meaning 3 lines 8 phones and grows to 8 lines 24 phones by adding another 308 and 208 card. So, if you're adding line 4, you need to have the expansion card to make it work. These systems come with at least 2 and maybe up to 6 manuals. I would hope you don't plan on "adding one more line" without it.
Carl
Apr 03, 2011 | Panasonic KX-T7730 Corded Phone
I have panasonic kx-t7730 phone .i have 3 lines in same number from my service provider .2 lines are already assinged its working fine my 3rd line is not working when i try to press the 3rd button its...
Your 7730 is just a phone. The programming is done to the SYSTEM that the 7730 plug into, from either a maintenance program on a PC or extension 101. There will be a programming manual (PM) for the particular system, be it a TA-624, 824 TAW or different system. In system programming, you turn the lines on in system program 400 and adjust the ringing in programs 407-409 (TA codes). You also have to plug the 3rd line into the CO3 port on the cabinet.
Carl
Hi I have a panasonic KX-T7730 and I need to connect it to my linksys PAP2T Device. but I haven't Voice Over It. can I use this device with KX-T7730?
The 7730 is a Panasonic Analog System phone. It plugs into a Key Service Unit and the line port plugs into the PAP2T device. Model numbers like KXT-A624/824 are examples.
Carl
Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Call fwd
Let's see if I can be 3-3 :-)
If the 7730 is connected to a TA-824 system, you need to have 3 elements in programming, an access code that gives you an outside line, 9 works if your lines are properly programmed in system program 400, and 81,82,83 codes work if not. The problem with 8x codes is that it only gets a specific line and if that's busy, it doesn't work.
You also need to turn on the option in programming. Reference the following thread http://www.fixya.com/support/t3120724-forward_calls_outside_number
Carl
Oct 15, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7731 phone cuts off/mutes on hold music
My guess is that you have a KXT-624 or 824 system.Follow the instuctions here: http://www.onholdplus.com/products/7000series_connect1.html
Then, if you get lucky, when you go to any system phone and press "1" without picking up the handset, the music will play.
If it doesn't and you don't get MOH, you may have to do some programming in system program 111.
Carl
Mar 19, 2009 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
384 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
