Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Hey I have a Whirlpool Ultimate Care II that wont drain. I checked the lid switch and got an OHM reading across circuit when i click switch.. This means the switch is working, right? The washer fills and agitates fine but when gets to the pause part of cycle, never comes out of it.. doesn't seem to be trying to do anything.
    Genius:
  • 1,073 Answers
The timer is the issue
Posted on Apr 13, 2008
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not drain
check the lid switch,close the lid,open it a few inches and close it down,you should hear a clicking sound no click bad lid switch
Mar 18, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Hi Dennis! I have a whirlpool ultimate care II washing machine. It agitates, but will not drain or spin. any suggestions?
Check your lid switch, you should hear a click when you open and close the lid. If you don't hear a click, replace the switch.
Oct 17, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Our ultimate care ii is not working properly. it
the lid switch is broken,open and close the lid if you don't hear a click that's a sure sign the lid switch is broke,try sticking a pen or something in where the switch is you might get it to spin and drain but you gotta change out the lid switch
Feb 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin, won't drain
Hi...
If your washer does not drain, you need to check this:
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
If it does not spin check also this:
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hey
look inside your pump it sounds like you have something stuck in it like hair button money pen or another foreign object jammed in there
don't ask me how i manage a building and fer christ sake if i don't have to fish out at least 1 pen per week from a pump impeller
im surprised
Oct 28, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Ultimate Care II, model LSQ9010KQ0
lid switch lift lid and listen for click when lid shuts.. believe switch on rear left just behind lid hinge or on older models right side about half way opening (ck for boken lever or screw holes)also hinge may not be fully contacting switch ckd hinge screws just in case first if too much play in hinge will fail to contact switch..switch may be acessed by removing screws in bottom rear corners on back of console and lifting console
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
WUC II
check the lid switch, if it is ok go to the pump and see if anythig is in it, if nothing there motor issue
Apr 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't start spin cycle
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
Mar 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
112 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
