Question about Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
My nikon s220 shows lens error and the lens remain out an dont go in...otherwise da camera jus makes clicking noises...tried banging it on ma palm but nuthin happen help plse!
    New Friend:
  • 94 Answers
Clicking noises suggest the lens is either knock damaged or jamming because of sand - probably a marginal repair.
Posted on Jun 09, 2010
SOURCE:
Lens error
can you hear a clicking sound when you put the cam on? if yes the lens is broken and needed to be fixed by Nikon. its an internal problem. try bringing it in customer help in NIkon.
May 28, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My nikon coolpix s220 have a lens error and when i turn it onthe lens goes in and out like its trying to focus and it makes a wierd noise. it also wont let me do anything it just pops up saying lens error
Try removing the battery/batteries and clean the contacts underneath. Also, clean the battery contacts and the charger, if so equipt. To do this, dampen a cotton swab with rubbing alcohol and rub the contacts. Blow into the compartment after to clear any residue.Thanks, Dana
Jan 03, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My nikon S220 has a lens error makes weird noise and the lens goes in and out 6 times when i turn it on. Help
Lens is probably just stuck, because of debris or misaligned gears. The lens can in about 50% of times be repaired without having to replace it. Try to return to manufacturer. If you're out of warranty, there are third party place that fix them such as camera lens repair. There are also free camera repair guide websites that show you how to replace the lens, the part is usually available on ebay.
Jul 02, 2010 | Nikon Coolpix 2200 Digital Camera
Nikon s220 lens error
The s220 seems to be very susceptible to lens errors, usually associated with the lens barrel being unaligned. It only takes the slightest bump/drop in many cases. Fixing it is a hit or miss solution. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Has a good list of possible fixes.
Jul 06, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Re Nikon S220 digital camera. Lens error noted -
A tiny bit of grit can jam the gears of the lens. Sometimes a tap can knock it out. Try this at your own risk. Take out the batteries. Don't hit the camera on a hard surface, just use you hand. If it hurts, that is too hard. Try lens down, then all the sides.
May 29, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon S220. Lens error. Turns on but displays lens error only.. Cannot take pics
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 15, 2010 | Nikon Coolpix 2200 Digital Camera
Lens error in nikon s220 digital camera.
Yes you right. After fall down the lens internal guide pin is damaged and thats why its happens. a912d76.jpg So visit your nearest service center for repair. Thanks.
Mar 14, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
S220 Coolpix has a lens error problem, turn camera on tries to focus (Lens moves in and out making a weird noise) but comes up with a lens error problem
Did it drop? sounds like the motor is trying to move the lens as you need, but the lens has come out of its tracking. If there is no outside damage and you still have warranty left, you should get it replaced, otherwise it means opening it to place the lens back on its tracking, but this can be tricky.
Jan 05, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Ok ive had my camera for maybe one week its a nikon coolpix s220
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Jul 08, 2009 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
1,633 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
