Scott,
The fuses that I found bad on my 50H81 were F850, F851, and F852.
Those were the only three that I found bad and I checked them this morning and they are all still good.Thanks for all your help.
John
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
Upon turning on set I got flashing red power light and nothing else.
Removing plug for one minute and plugging in results in:
Audible click, steady red power light for 2 seconds then slow flashing red light
Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
Removing power cord for several hours and plugging back in made no change
Audible click, steady red for about 2 seconds then slow flashing red light
Possible related note:Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
Fuses F850 and F852 found blown
Repairs Made:
PD0074 DEF/CON Power Board
There are two main power supply capacitors in this set.They are C-809 and C-810.One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time.When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
Replaced blown fuses F850 and F852.
I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
Already owned Service Manual and Circuit diagrams from a different 2004 repair.
Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
Some solder. Already owned de-soldering tools, etc.
Visited both local authorized Toshiba factory service repair facilities.One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU!Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
www.partstore.com will have the fuses you need F850 and F851 are part number 23144627 125V 5.0A axial and F852 is part number 23144624 125V 2.0A axial just enter those part numbers in the search box for part number and they will have your fuses.
its possible that flood leaked on board from a tube leaking. clean the area and scrape the burnt area really good so that it won't conduct. then make a jumper from some small wire to the areas you need. check tubes on the bottoms of the metel areas not the crt for something wet... if this fixes your problem then cover your board with a plastic or foam sheet so that it drains forward away from the board. also when you find what tube it is, you may want to ask ways to fix it or how to keep it from leaking. but if its not a leaky tube then you may have had lightning or power surge. may want to go ahead and check all parts connected to that area for a short. just to make sure there isn't another problem before you start it up. good luck let me know.
ok i'm goin to need more info about your problem. you stated fuses and didn't say the location numbers of the fuses. Also, have you rechecked your fuses to see if they are all still good? 3 fuses sounds like more then one problem. once you tell us your loc#'s of your fuses, we can look into your problems.
Check fuses on Power Supply board (F850, F851, F852) and all other fuses. Replace blown fuses (will need an ohm meter to check fuses). I would also replace the two convergence amps (STK392-110's on the signal board, the big black ICs on the two heat sinks). This worked for me.
First step is to use an ohmmeter and check all fuses including
small,soldered in kind called micro-fuses.....F850,F851,F852 etc
.................................T.
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
You might want to check http://tacpservice.toshiba.com/TACP/subpages/pdfs/TechBulletinsTV2002.pdf
the first Item talks about power LED lights Power supply does not start
