Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Printer want conect 010-397 Restart Preinter Dell3000cn express service code 18567557605
  • 1 more comment
  • Anonymous Nov 03, 2008
    error 010-397
  • benwaleed Jan 04, 2009
    I have the same Problem here.
    meesage appeared: 010-397 Restart Preinter
    Printer Model: DELL COLOR LaserJet 3000cn
    please advice...
  • benwaleed May 11, 2010
    more clear? OK...
    When I start to turn on my printer I get the message mentioned in my first post. can print, can't scroll through the Menu.
    any help, smilemaker?
    regards;
I found the solution here http://www.csudh.edu/CLASS/voffice/dell3100printer/Contents/section19.html
The error indicates the outer levers on both sides of the fuser unit are not securely locked. On my printer, I removed and reinstalled the fuser.
Posted on Apr 19, 2009
    Problem Solver:
  • 18 Answers
Fiend your solution direct from EPSON. Here is your solution...
printer want conect
http://www.epson.com/printer/prob676ijt65/solution
aqq-9
Posted on Sep 03, 2009
  • 790 Answers
Hello sir ,
Can u please be bit more clear in your query
Posted on Apr 11, 2008
962 Preinter will not print color
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Dell 962 Photo All-In-One InkJet Printer
I have P2015n laser jet network printer. Since last two days garbage printing is contineously going on how to reset or stop this printing. Pl. give solution. Nitin Joshi adminnsk@ksb.co.in
1, Go to your services and restart Print spooler (start-run-services.msc) start stop it 2. Reinstall printer driver 3. Check your network or USB cable (depends how you have conected it)
Best regards
Mar 01, 2011 | HP LaserJet P2015n Printer
My printer will not turn off. The document will not cancel or print.
go to run and type services.msc
and press enter
now go tp print spooler option and selscet the service stop and start. then cancel the print job from printer and remove the poer cord of preinter and connect it again.
Sep 07, 2009 | Lexmark P4350 All-In-One InkJet Printer
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
Brother printer mfc-8860dn
This usually means that it isn't picking up paper at all. Draw and x on the top paper and see if it takes it. You may need a new feed tire or different paper.
Apr 28, 2009 | Brother MFC-8860DN All-In-One Laser...
CANON IR 400 COPIER - ERROR - E677
Sep 11, 2008 | Canon imageRUNNER 400S Copier
When trying to install software for Lexmark x2580 it seems to hang part way through. Heve tried several times from disc, and downloaded software from Lexmark. Message in bottom right states 'a problem...
Hi ,
Definitely u install printer through connecting printer to pc .that's why the problem is occure........
please uninstall of drivers& software of printer restart pc with disconnecting printer from computer...
then install software for printer ..follow the instruction ..then when pc notify u to connect printer/harware detection then connect printer to pc & get printe on ....i am sure u r printer will be detected & install scessfully done
if this information is useful for u please Rate me.........
Jun 14, 2008 | Lexmark Office Equipment & Supplies
Installed drivers and set up new unit per instructions,unit will not scan or print from any user
open the nprinter folder and confirm that your preinter is set as the default printer,try and print a test page,then send your printing jobs,good luck. eyo7 eyoifiok2005@yahoo.com
Mar 30, 2007 | Lexmark X7350 All-In-One InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
544 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
