OnBoard Marvell LAN Driver, Modem
I formatted my noteboke 2 weeks ago and i couldn't find my Interlligence Update CD, and right now i can,t connect my laptop to the internet and i have no sound drivers. Can You PLEASE help me download Lan drivers so that i can be able to connect to the net. I'm using LG LE50 EXPRESS
  • David usen
    David usen May 11, 2010
    dosto send the model no of your laptop
    check the bottom of the laptop for the real model no,cause the one you post here is'nt it
Lan driver
The Asus P5PE-VM mainboard uses the Marvell 88E8001 GB LAN controller.
You can download the LAN driver HERE.
Sep 23, 2011 | ASUS P5PE-VM Motherboard
I need lan drivers for intel D915GRV motherboard of desktop
You can download the motherboarddevice drivers from Intel WEB site. Select your model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers thatmatches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Jul 27, 2011 | Intel D915GAG Socket 775 Motherboard -...
Unable to use LAN
if you are reffering to your internet connection
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver,disable,uninstall or select properties general you will have the options to troubleshoot or to update driver,rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
also you might check
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Apr 12, 2011 | Computers & Internet
After formatting Hard disk & loading new windowsXP SP2 ,i am unable to connect internet through my mtnl router HG520 ADSL2+
you need to install network adapter first before you can connect to internet
check it at device manager, is there any yellow mark?if yes insert you motherboard cd driver
then chose to install LAN card driver
the otherway is install from device manager. with cd driver inserted right click at yellow mark then chose update driver, follow the step untill process finish and the yellow mark at device manager disappear
try to connect to internet through your modem
i hope this helpful
thank you for using fixya
Feb 12, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Onboard lan not working even after update of driver gives windows error
Hi Good day!! What message of windows error? Check your network adapter in the device manager, if it is install if not pls try the following.
1. On the desktop right click "My computer and then properties"
2. go to Hardware tab and then click device manager check the network adapter.
3. Disable it and then re enable it. hope your on board lan will work now if still not re-install your lan driver through your motherboard cd..
pls reply o assist you more..
REGARDS:
JR
Oct 07, 2010 | Biostar TA785G3HD AM3 AMD 785G HDMI Micro...
Marvell yukon 88 E 8055 PCI trouble
http://www.fixya.com/support/r4871388-installing_missing_drivers_free_charge
Use this tutorial to see if your drivers need updating.
May 21, 2010 | Microsoft Windows Vista Ultimate Edition
I Have ASUS P5RD1-VM series motherboard of which the LAN driver is being missing all the time. Pls. anybody help me. Regards Sachin
Open Advanced while in the bios. Than open Southbridge configuration.
Please check bios for Onboard LAN Page 2-24 in you're manual. Set this to [Enabled]
If you do not have this enabled the LAN controller will not function.
Once enabled in bios save and exit the bios menu.
Open windows update when you're system reloads.
Click the custom button when windows update open’s.
Windows update service will scan you're system and will see you're LAN is enabled.
Windows will list drivers for you're on-board built-in LAN controller.
Or you can use the Asus CD to install the LAN controller software.
If you're LAN controller does not function you may need to add a PCI eithernet card.
Mike
Apr 12, 2010 | ASUS P5RD1-VM LGA775 Motherboard - ATI...
Is not establishing connection to modem
cause the connection to teh modem its made by the tcp/ip protocol ...put into get an ip address automatically ..so it can not be a issue of a wrong ip or so ....the issue it is either with the modem ...and this can be solved by runing again the cd that you have from the internet provider.....or it is cause you do not have the right Lan driver installed..and this can be solved by inserting he motherboard drivers cd and choose lan driver from the list and install...after finish installing again the lan driver ..open the internet connection ..choose properties...than tcp/ip from the list ...with double click ...and on the configuration choose get and ip address automatically ...aply ..and ok ...you should have a connection in this moment..
Mar 29, 2010 | Microsoft Windows XP Professional for PC
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
Will not reconize ethernet cable
Please ensure the following:
1. Make sure you use the LAN port.
2. Ensure the cable is in good condition. Try using new cable.
3. Ensure you installed proper network card driver.
4. Ensure the network card using correct link speed (100Mbps).
5. Try switching the link speed to Auto, if you're not sure.
These are the basics. If possible, try installing the latest firmware for your network card. Normally, downloadable from the manufacture's site.
Regards,
Maha
Jan 16, 2009 | Microsoft Windows XP Professional
Computers & Internet Logo
596 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
