I have a AIWA XR-MDS7 EZ sup mini stero unit, the lcd display is dead although the unit works I cannot tell what disc is playing or track number. Also I cant tell what radio station is playing. Everything works perfectly apart from no display. I had a friend look at it and he recons the display is getting a signal.
  • 2 more comments
  • mojo35 Apr 18, 2008
    Thanks A mill !! i will get cracking on it & and keep you posted.
    Hiya .. I checked all the pins - they are all fine, the guy that had a look at it first used an oscilloscope to check the signal to the display and all was ok. LED I assume has lots of little lights where as LCD does not - based on this assumption mine has a LCD display. The only lights working on the unit are the power on and the changing colours around the volume button and the cd tray when you power it up.
    Here is a pic of the unit - if it helps .
  • mojo35 Apr 21, 2008
    Will get those readings posted asap.
    Thanks
    mojo35
Http://klausnahr.wordpress.com/2007/06/19/aiwa-xr-mds7-display-reparieren/
a fuse is dead , change with a new one, things will be fine!!
Posted on Dec 02, 2010
  • 4,234 Answers
The first thing to check is the solder connections on the display itself. Look specifically at the connections on either end of the display. These are the supply pins. Also, I don't know if this model has an LCD display or LED. If LCD, then make sure that the back light is funtioning.
Keep us posted on what you find.
Dan
Posted on Apr 11, 2008
  • ABRsvcs Apr 18, 2008
    First, from looking at the display, you won't se the individual lights. Was the display red or a gray color? Also, the signal lines are not the issue here. The pins at either end should have DC voltage on them. If they do not, the display won't work. Post the voltage readings here if you can.
    Thanks,
    Dan
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
CD playing erratic
Run a "Laser Lens Cleaner" thru the unit a couple times. Use one that takes fluid, you can find them at just about any retail store for 15-20. If that doesn't solve it, it needs to be repaired. At that point weigh the cost over replacement. A new transport usually will cost 100-150 on average for parts and labor. Hope this helps
Jun 23, 2009 | Audio Players & Recorders
How to play CD on Aiwa NSX-3500 (part of CX-N3500U) w/o remote control?
I thought that I had the same problem. I then discovered that when I put 3 CD's in it started up on it's own. If you push the demo button you can see how it's supposed to light up the number of tracks in a square on the right of the display. It wasn't doing that until I put in all 3. Then it started up and I was able to use the disc 1, 2 & 3 buttons to change from 1 CD to the next and I used the Up and Down buttons to change songs and the play button above the tape deck is multi-functional. Hope this helps.
Aug 13, 2008 | Audio Players & Recorders
Aiwa xrm98 hifi need the remote model number for this hifi
I think your remote's part number would be RCZAT04 and you can get the current substitute from HERE.
Hope that fixed Ya...
Geno
Mar 28, 2008 | Audio Players & Recorders
Aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Mar 18, 2008 | Audio Players & Recorders
Aiwa xr-ms5 cd recognition problem
If your player won't recognize a disc, make sure the CD is properly loaded and not scratched, and that the lens is clean. Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully. Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function. good luck :-)
Jan 06, 2006 | Aiwa XR-MS5 CD Shelf System
390 people viewed this question
 Grubhead
Grubhead
