Question about Aiptek A-HD 720P Flash Media Camcorder
Charging battery on new purchase.
Have brand new 720P but can't charge battery. Only get green light both from wall soc ket and pc outlet. Have made sure that camcorder is powere off when uusing using USB port
  • Anonymous Apr 16, 2008
    please help same problem
  • gunner1934 Apr 23, 2008
    Thanks, I did the same thing. Felt silly, but glad someone else had the same problem!!
I just got this camera today and i was having the same problem. i figured that i would just leave it while i was at work and see if it needed a full charge or something. when i got home, nothing. it would only power on when plugged in. after a little checking and swearing i found that i had put the battery in backwards. it will fit in backwards but will not charge it. the writing on the battery should be visible when it is in place. hope this helps.
Posted on Apr 23, 2008
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Laptop won't come on even when plugged to wall outlet
you will likely need to remove the battery pack to run the unit. If this works, you will need a new battery to use the laptop portable.
Jun 09, 2012 | Acer Computers & Internet
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
I am charging the battery of a brand new purchase. Do I need to let the battery charge fully, ie; the 3.5 hours before I can use it? I keep getting a, "Key LOCKED, system shutting down message on the...
For the initial charging, YES, you need to follow what's on the manual. If it requires you to charge the player for 4 hours as the initial charging, you need to leave it connected to the wall outlet for 4 hours, so that the battery life will become longer.
Though the key is locked, it's still charging. As long as it's connected to the outlet.
Thank you.
Nov 03, 2010 | SanDisk Sansa e200 MP3 Player
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
We have never been able to charge our VPC-T700. We bought it new and haven't been able to use it after the batteries died. How do you charge it?
The AC power adapter may charge the battery. Make sure that the poser of the camera is off and then insert the battery before starting.
1. Connect one end of the adapter converter to the end of the AC power adapter. Make sure camera is off.
2. Insert the other end of the adapter converter to the PC/AV terminal on the camera.
3. Insert the other end of the AC power adapter into a wall outlet. The status LED lights green when charging is started and lights off when charging is completed. It lights red when a charging error has occurred.
Oct 10, 2009 | Sanyo Xacti VPC-T700 Digital Camera
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Aiptek A-HD 720P Flash Media Camcorder Logo
165 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
prouddad_1
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
