Epson Stylus Photo 785EPX InkJet Printer Logo
Posted on Aug 16, 2017
Epson stylus photo 785epx printing rows of blue dots behind text
My dads epson stylus photo 785epx inkjet prints rows of blue dots behind everything printed which can mostly be seen behind the text. It used to print normally at some point so I was wondering what the cause of this could be. He has cleaned the printer heads and done the test prints (which also has blue dots) as well as gotten a whole new ink cartridge to no avail. Any help is appreciated!
5 Related Answers
Anonymous
  • Posted on Oct 25, 2007
SOURCE: Epson Photo RX620: Printing Pink Lines
None of these answers are accurate.  I know precisely what your problem is, and you aren't going to like what I have to say.  What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer.  I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue.  I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem.  The issue you are having is with the Epson print head, which uses piezo technology.  What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber.  It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet).  Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture.  Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy.  The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head.  It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head.  Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it.  If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not.  Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol.  However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed.  If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours.  If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem).  The solution is to acquire a new print head.  Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer.  Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge.  Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy.  Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
Soulvisitor
Soulvisitor
  • 1113 Answers
  • Posted on Nov 04, 2007
SOURCE: Epson STYLUS CX3900 Black colour not printing
Are you using gen. epson cart? If not then try that first.
Sounds like you have a block black print head there are many posts on that subject.
A
Anonymous
  • Posted on May 01, 2008
SOURCE: Epson Stylus C86 won't print
The ssc program doesn't work if your ink light is solid red.
Anonymous
  • 84 Answers
  • Posted on Oct 19, 2008
SOURCE: how to fill Epson Stylus
If you are trying to replace an ink cartridge you may use the link below.
http://tinyurl.com/55yau2
Keep me posted.
Thanks.
Jeff
websnail
Martin Smallridge
  • 419 Answers
  • Posted on Feb 15, 2009
SOURCE: R2400 EPSON PROBLEM
Yikes... lot of these lately..
The solution in this thread will provide the answers you need.
http://www.fixya.com/support/t1544015-epson_r_2400_top_trashcan_light_ink
When printing text I get extra lines or dots of ink next to or under the printed text
It sounds like you have lint on the bottom of the print head. ttle fuzz balls will collect down there and they catch drops of ink and leave little lines as they go across the page. buy an Epson head cleaning kit on ebay. It will include a cleaning fluid and a special foam tipped cleaning wand. Do not use a q-tip.
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Epson Stylus Photo R320 InkJet Printer not printing black or yellow
I had same problem, fixed mine like this... just choose the head cleaning option and run this about 5-10 times in a row takes about half hour or twenty minutes but it starts printing black eventually.
2answers
Does the Epson Stylus Photo R340 Printer print non photo documents in plain text?
yep, these photo printers print text aswell, just designed to give a better quality photo print
1helpful
1helpful
Epson 785epx has sponge type material in the paper tray which came from underneath the guide bar for the ink cartridges. Printer goes through the printing cycle with no ink on the page.
The sponge is the head cleaner. It cleans the dried ink off the print headwhen you start a print job. If you don't replace it, your print head or cartridge will be ruined.
2helpful
Printing error I L b
that means that the black cartridge is low on ink. Make sure to have a replacement black ready.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
