Question about Toshiba Satellite 2455-S305 Notebook
Toshiba 2455 S305 Laptop
I'm getting horizontal white lines on the LED display. It used to be ONE white line & has now increased to FOUR white lines. Paul Solomon-Pensacola, FL
Miss/Mrs. Pterocarpous,
You are obviously Greek. I hope you enjoy Feta Cheese Salads, French Fries done in Olive Oil, Goat and an occasional glass of Retsina (always served in Athena and Souda Bay).
My problem sort of healed itself (white lines gone). However, I've decided to buy a new machine from Best Buy and donate this one to charity while it still works.
Thanks again,
Paul Solomon
Posted on Apr 18, 2008
    Sergeant:
  • 202 Answers
Hello Paul,
Do you see these lines...
(A) As soon as the computer has been turned on?
(B) Only after entering into your operating system user profile?
I suspect the answer is (A). If it is, then it is quite possible the LCD panel has failed.
A quick way to pin this down is to connect an external monitor to your computer. If the problem does not show up on the external monitor then, indeed, your LCD panel has failed and will need to be repaired or replaced.
Please, post back w/ the results of your having tried an external monitor along w/ any other comments and observations you might have.
** Please, don't assign a rating to any of
** the experts' recommendations until your
** problem has been resolved or diagnosed.
** Once ratings are assigned, the problem
** will be closed and we won't be able to
** continue to assist you. We WILL keep
** working w/ you on your problem is re-
** solved or diagnosed.
Thank you,
BJ @:)
Posted on Apr 11, 2008
  • B Joan Rapier
    B Joan Rapier Apr 11, 2008
    If the issue appears on the external monitor as well, then we must consider the possibility of an issue w/ your laptop computer's integrated (built-in) video hardware.
    Please, let us know the results of this test then we will be able to direct you in the next steps to take.
    Thank youg again,
    BJ @:)
  • B Joan Rapier
    B Joan Rapier Apr 17, 2008
    Hello Paul,
    How did it go? Did the information I provided you w/ enable you to determine whether your LCD panel had failed or not?
    I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to work w/ you to diagnose the problem.
    If it is the case (that you were able to diagnose the problem w/ my assistance), would you kindly take just a moment to assign a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
Tip
I am facing a problem with Media Control Devices, I need to down load the same in my laptop.
Please help.
Nur
on Jul 24, 2008 | Toshiba Satellite 2455-S305 Notebook
How do I install intel pro/wireless 2915abg in a toshiba 2455 laptop?
Go to toshiba website. Click on support. Click on download. Choose a category, since this is a laptop. Select laptop and for the family. Select satellite. For the model, type on the model finding filter the 2455-S305 then click go. slect your all operating system and wi-fi. you will see there the available driver for your pc.
Apr 07, 2010 | Toshiba Satellite 2455-S305 Notebook
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and without the battery, and when I plug it in it start's flashing in the front, but won't turn on.
Remove battery and disconnect power cord. Press power button for about 5-10 seconds (without battery and power cord) Connect power cord only then turn it on.
Dec 01, 2009 | Toshiba Satellite 2455-S305 Notebook
Require part numbers for 2455-S305 hinges.
Toshiba Satellite 2455-S305 ...
Left Brake Hinge - P000368300
Right Brake Hinge - P000368310
http://www.impactcomputers.com/p000368300.html
http://www.impactcomputers.com/p000368310.html
Oct 06, 2009 | Toshiba Satellite 2455-S305 Notebook
2455-S305 goes to black scr w_fast blinking cursor
Hello there:
when you replaced the hard dive did you go into the bios and make sure that the harddrive was recognized and set up as the primary drive.
also you may be able to get around this by pressing the reset buttona on the back of the unit and hold in and turn on the power at the same time
than release after 10 seconds and if this still doesent work try to boot by pressing the f12 key as it starts up ok?
best regards michael
Sep 14, 2009 | Toshiba Satellite 2455-S305 Notebook
My toshiba satellite A-135-S4477is showing lines vertical on the screen
you have a bad display, if you press around the OUTSIDE around the display while the computer is on they should disappear, until you stop pressing on it the top and bottom are the areas to press upon with you forefinger and thumb, NOT THE DISPLAY, this will tell you, you have a damaged display and it needs replaced.
Jun 26, 2009 | Toshiba Satellite 2455-S305 Notebook
Vertical lines are appearing on my toshiba laptop
first try to hook it into an external monitor if it looks good,I would have to say you have a damaged cable on your monitor.if you are comfortable taking it apart you can try to reseat the ribbon cable on the mobo.you can usually find an online manual for disassembly.
Apr 23, 2009 | Toshiba Satellite 2455-S305 Notebook
Toshiba Satellite 2455-S305 Notebook Logo
111 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
