I have replaced the water distribution part on my aeg 72620 Lavamat as the original part was faulty. With the new part fitted and on a main wash the water is diverted to the pre wash compartment - is the timer / control pcb faulty also?
  • Washing Mach... Master
  • 19,396 Answers
If wates is diverted to the wrong compartment, it can be a faulty pcb, faulty control/timer switch, or valve not opening or obstructed duct.
Posted on Apr 11, 2008
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Mijn AEG oko lavamat 72620 meld code 9
AEG code 9- tacho/motor fault ;-0(
Sorry,
John C
Mar 19, 2011 | AEG Washing Machines
Aeg l 72640 e034 what is this
e34 is listed on the 72630 as a conflict between the 2 water level pressure switches. A simple solution can be a blockage in the pressure chamber that the 2 pressure tubes attach. a faulty pressure switch or a more likely miss reading of the level control by the electronic. You need to be able to configure a new electronic to fit it . not a diy job.
all the e3x errors relate to water level problems.
Jul 20, 2010 | AEG Lavamat 72640 Front Load Washer
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Aeg oko lavamat 72600 update, ce error code showing any idea?
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
AEG LAVAMAT 74620 shows "CE" error
I fixed it, but I still don't know for sure what the "CE" error code is. I guess it is for the water distributor. I opened it up. There are some gears in there that move a mechanical arm that distributes the water into different containers. The mechanical arm moves around an axis -- it was very difficult to move, so the gears kept slipping. I opened it, and put some greaze inside. Closing it up was a real pain. But it works, and I didn't have to wait around to receive a new distributor.
Dec 27, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Machine came up with E91 and then powered down
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Feb 19, 2008 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 72620 door does not open
It seems that your problem is with the lid switch and it should be replaced. The switch is inside the washing machine main housing near the door frame. You have to raise the top of the washer to get to the switch. Good luck!
Sep 05, 2007 | AEG Lavamat 72640 Front Load Washer
Washing machine AEG 72620 not functioning.
Having worked for AEG for over ten years, the fault is a faulty dispenser unit ( top of soap draw) only fix is to replace the unit ( cost approx £45)
Aug 29, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
