Question about Toshiba e-Studio 161 Copier Copier
Toshiba e-studio161 Developer
Sorry, don't know anything about printers except that mine needs help! red spanner and sun lit up on control pannel, which i gather means it needs developer. Only problem is i'm in the south of egypt and no one here can solve the problem. is there anything i can try doing myself?
any help appreciated!
  • Anonymous Jun 04, 2008
    ERROR
  • 62 Answers
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]“000””000” will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] “000””000” will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
CHANGING A TRAY’S PAPER SIZE SETTING
Follow these steps to change a tray’s paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
Use the [ORIGINAL SIZE ENTER] key
to select the paper size.
The indicator of the
selected paper size lights
up.
Posted on May 11, 2008
    Problem Solver:
  • 3 Answers
Hi firends,
I have faced the problum of repeat immagein toshiba e-161 machine, i have replaced new Drum Kit. But the copies having repeat immage, how to solve the problum, is it have any programe.
Posted on Nov 02, 2009
Howmany error syombel in e_studio161
Posted on Apr 06, 2009
How do I set for a4 copy?
  1. Toshiba e-STUDIO161 Operation Manual - ManualsLib
    www.manualslib.com > ... > Toshiba Manuals > Printer > e-STUDIO161 Toshiba e-STUDIO161 Service Manual 124 pages ... User safety This Toshiba digital plain paper copier does not produce laser radiation hazardous to the user.
Jul 21, 2015 | Toshiba e-Studio 161 Copier Copier
I want toshiba e-stodio dp-1620 user mannul
Toshiba Copier Model e-studio dp-1620 is also referred as Toshiba e-Studio161
here is the manual
1. Toshiba e-Studio161 user manual
You must have an Adobe Acrobat Reader to view this manual because its pdf format.
Let me know if this is the one you're looking for.
Feb 03, 2011 | Toshiba e-Studio 35 Copier
I can not run my toshiba power saver nither can i change my power settings manualy. I cannot find where the tishiba power saver option is iv already checked control pannel.and one mor thing, the infra red...
the infra red i dont know anything about, sorry. the power settings, most of the time are in control pannel .
if you haven't already solved your problem, try going thru
'control pannel', then ' performance & maintenance',
then 'power options'. anyway, thats where mine are located so maybe you'll get lucky and solve one issue. good luck!
Feb 09, 2010 | Toshiba Tecra M1 PC Laptops
Toshiba e-studio161 - windows7 64 bit
For Vista there is only a 32-bit driver. I've already tested, it doesn't work
Dec 09, 2009 | Toshiba e-Studio 161 Copier Copier
My Toshiba Studio 150 has a wrench lit up on the screen. Any Ideas?
Hi, the two main reasons for the Maint error light (spanner) to come on are the toner warning when it reaches 10% full and the developer when it reaches 25k count. The light can only be reset by entering one of the pre programmed simulations on the machine and clearing the error.
Dec 08, 2009 | Toshiba e-STUDIO 150 All-In-One Laser...
How can I install Toshiba e-studio161 as a printer, even if in the printerlist of my HP-Computer Toshiba is not listed? Thanks for helping Sr. Relindis
first u check pirnter hardware found or not in the system. then switch off the printer run the setup file.when setup s finshed restart the system
Sep 30, 2009 | Toshiba e-Studio161 All-In-One Laser...
How can i get driver for estudio 161 for windows 2000. can u help me with link site? Thanks
Here is the link for your driver:
http://copiers.toshiba.com/support/controllers/e-studio161.shtml
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 24, 2008 | Toshiba E-Studio 161 All-In-One Laser...
Toshiba e-Studio 161 Copier Copier Logo
1,590 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
