Question about Dell Inspiron 6400 Notebook
Memory can i up grade the memory from 1gb to 2gb. and how simply is it to do
  • 46 Answers
Your Inspiron 6400 can use a maximum of 2 GB. If you turn the notebook upside down, you should see a "door" held shut by two screws. The door has what looks like three rows of ridges or slots on it. Loosen the screws and remove the cover. Determine if one 1-GB or two 512-MB modules are there (just note how many). If there is one, you need to get one more and add it. If there are two, you will have to buy two 1-GB modules, and replace both old ones with them. Now, you need to see if you'll be comfortable doing it yourself. Ground yourself (if you do the work near a kitchen sink, touch the faucet). You will see two metal clips on the sides of a memory module. Using your fingernails, pull them slightly away from the sides of the module. It should spring up slightly. Note the angle it's sitting at. Grab the sides ONLY of the module and pull it away from the socket. Easy, huh? Now, put it back. Slide it into the socket at the same angle. Push down gently on the long edge opposite from the socket. The side clips should click into place (into the notches).
If you're okay doing this, go to www.crucial.com. On the right side of the page, use the top drop-down box to select Dell. Use the second box to select Inspiron Laptop. Use the bottom box to select 6400. Click on Go (or whatever the search button label says). You will see what you need to order, based on the quantities mentioned above.
When you're finished with a module replacement job, replace the module door.
Posted on Apr 11, 2008
Upgrade vgnnr160e memory
If the laptop will take 2GB, purchase two identical 1GB chips. They will work faster than one 2GB chip. A useful site is http://www.mrmemory.co.uk/
Mar 22, 2014 | Computers & Internet
Repeatedly long beeps
If you upreage the RAM to 2Gb by inserting a 2nd 1Gb memory module then the 2nd RAM maybe faulty or incompatible.
If you insert a 2gb memory module to replace the 1Gb memory module then it maybe faulty or incompatible.
Try using the same make and RAM speed as the original RAM module.
Dec 29, 2012 | Biostar G31-M7 TE Motherboard
Just installed 2 2GB cards (Corsair VS2GB800D2) to replace the 1 1GB card in my emachines EL1200 series. Computer will not boot. replaced the old card and it booted right up.
Will it boot with only ONE of the 2GB memory-sticks installed?
Will it boot with ONE of the 2GB memory-sticks AND one of the 1GB memory-sticks?
Look closely at the 1GB memory-sticks.
Does the label show 'DDR266' or 'DDR333' or 'DDR400' or 'PC2100' or 'PC2700' or 'PC3200' ?
Do the 2GB memory-sticks have _identical_ information?
It's definitely _not_ acceptable to have "slower" RAM (smaller numbers) in the new RAM,
but it _might_ be acceptable to have "faster" RAM (larger numbers).
Nov 12, 2010 | E-Machines eMachines Desktop PC
Whatis the maximum memory the medion rim2520 pc
Standard Memory : 512MB or 1GB Maximum Memory : 2GB ( 2 x 1GB) Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM
Oct 08, 2009 | Computers & Internet
CAN YOU BUY 1GB UP GRADE MEMORY FOR THIS COMPUTOR
Yes! it is possible and it is very easy if your motherboard supported it. You can replace.
Thank You
Jul 30, 2009 | Computers & Internet
Removed 1gb memeory and installed 2gb but only 2gb recognized
You may need to go to your manufacturer's website for toshiba, and flash your bios with the latest flash for this.
Sincerely, Ryan Deschaine Systems Engineer Boxen Solutions LLC http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Jun 30, 2009 | Lenovo T7200 Notebook
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Memory up-grade
you can go max 2GB (1GB each) DDR333 PC2700.
you have to reset the bus rate to match the RAM speed.
if you stay with DDR266 then you don't have to reset the bus rate
Nov 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Yes i bought a memory card 2MB for my LG CU500v & when I insert the card into my micro sd slot on the back of my phone & turn it back on it says that the card is not ready. what am i doing wrong?
simply turn off the phone before inserting it then turn it back on again.
But let me inform you that your phone memory supports up to just 1GB(hope you are not mistaking 2GB for 2MB: there is no 2MB memory in the system)
just purchase a micro SD card of up to just 1GB (nothing more)
and also make sure it is working before you leave the shop.
good luck.
May 12, 2008 | Lands Phones
Compaq presario c714nr upgrade memory too 2gb laptop
http://h10032.www1.hp.com/ctg/Manual/c01301275.pdf
Page 43 of this manual seems to have the best documentation on memory for this machine. I saw a 2GB max in another document and this shows the biggest module as 1GB. I would believe that infers a pair.
Dec 18, 2007 | Compaq Presario 700 470024-192 Notebook
Dell Inspiron 6400 Notebook Logo
42 people viewed this question
Alun Cox
