Question about Intel Motherboard
BOOT PROBLEM After I disconnect my PC from the power outlet, unplug the power connector or turn-off the AVR for a few minutes, whenever I switch on my PC again it won't boot.The PC turns on but nothing appears on the monitor. I tried refreshing every single connection on the motherboard but to no avail. I even removed the memory RAM and I didn't even hear no beep codes. But in the end I was able to properly boot my PC only after I exposed it to electric current by leaving the AVR turned on for at least an hour. I also noticed that when I was able to boot my PC that the clock is stuck at the last moment the PC still has power. I think the problem is whithin the motherboard itself because I don't have any adapter cards attached on the motherboard slots. But I still would like to hear any opinion anyone might have on this dillema. THANK YOU!!!
  • OSCAR BORJA
    OSCAR BORJA Apr 11, 2008
    I also tried using my old 230W PSU that I tested on this motherboard and worked fine just a few months ago, but it still didn't solve the problem.
  • 53 Answers
Hi
Pl change the PSU AND check it .
Pl tri it
Was this soultion useful? show ur appericiation by rating it
Posted on Apr 11, 2008
Tv won't switch on following power being turned off/on by electrician installing external light
Have you tried different electrical outlets? Maybe the circuit breaker for your particular outlet blew when the electrician turned the power back on. Or maybe the electrician disconnected power to that particular outlet.
Also try leaving tv unplugged for 30 minutes or so, then plugging back in [to a known good outlet] to see if it will turn on.
Apr 27, 2016 | Televison & Video
The PC won't start, won't even reach the boot up stage. Keeps tripping and trying to power back on.
Open it up and turn it on and see if the power supply fan stays on if not replace it.
If it was a bad memory chip the beeping wouldn't stop.
Feb 29, 2016 | Computers & Internet
The problem is when ever I start up my PC and turn ON the power button of my AVR the PC power switch goes ON and theres is a message NO signal in the screen, I have try to clean the memory and also try to...
You can try two things:
1) Unplug the power connector from the power supply to the motherboard and reconnect and try to restart PC.
2) If this fails, try replacing the power supply.
Jul 07, 2010 | Acer Aspire M1641-U1521A PC Desktop
DFI ns35-tc/tl Total power off requested. When pc is turned off,a red led light keeps shining, indicating motherboard is still powered. This is probably the reason that a USB Power Saving Center will not...
The red light is just a pilot light indicating that it is still
connected to the power line. To get it totally off, is to
unplug the unit from the outlet. If your PC is connected
to the AVR (Automatic Voltage Regulator), just turn the
power switch off at the AVR. Hope this help you.
Dec 09, 2009 | DFI NS35-TL Motherboard
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Medion desktop does not boot up, screen blank.
Had same sounding problem with a Medion PC myself. I don't know the cause exactly but the fix I have is this:
Switch off PC, switch off PSU and unplug the power cable from the PC. Then press the power button on your PC. You may see lights and fans start up for just a brief second. This is because there was still charge in the PSU's capacitors which we needed to clear out.
You can now plug the power cable back in, switch on the PSU and turn your PC on.
(I realise this is too late for the original poster's uses but others may find it useful when searching for a problem!)
May 18, 2009 | Medion MD1917 PC Desktop
Computer does not boot up.
First of all, power down, remove all cables and check to see if your Graphics card is inserted correctly. Also try removing and re-seating the graphics card.
Check the cable from graphics card to monitor. Also try cable and monitor on another pc to eliminate this possible cause.
Failing that, you could have a BIOS problem.....did you recently try to flash your BIOS chip??
Apr 05, 2009 | Soyo SY-K7VME Motherboard
Dell pc dimensio 5150 wont boot up
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (where power cord goes into unit).
Also try simply unplugging the unit from the wall outlet for a minute then plug it back in and boot it up.
Feb 14, 2009 | Dell Dimension 8400 PC Desktop
How do i get to the head light switch on a 1999 dodge ram van
hi vern , 1. Disconnect negative battery cable , Open power outlet door and remove instrument cluster bezel retaining screw , pry cluster bezel from clips securing it to instrument panel , disconnect electrical connectors from power outlet ( cigar lighter) to bezel remove cluster bezel .
2. remove 3 screws and headlight switch , disconnect electrical connectors , pull knob and stem to stop limit , hold down on button on top of switch and remove switch ,remove 2 screws to bezel .reverse removal procedure .
i just did one of these due to headlights going out whenever they feel like it , and i found the electrical connector all burned and black looking , the new switch came with a repair harness connector , had to cut off old connector and crimp on new connector , it was a fix . thanks for voting ! and good luck .
Jan 03, 2009 | 1999 Dodge Ram
Compaq desk top power problem
I am sure that donster74, info will work in your problems , all you have to do is connect and refixed all the conenction from the power outlet to you computer. the computer should have power or else the power supply got wrong. verify the outlet if have power on it.
Any problem arising the solution please tell me sothat i can tell you more troubleshooting on it. do not rate me if still problem on it.
best regards, melnavz
Feb 21, 2008 | Compaq Evo D500 PC Desktop
Intel Motherboard Logo
41 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
