Question about Behringer EUROPOWER EP2500 Amplifier
Ep2500 amp It made a thud noise with no signal running through it the fan still working and green light still on.Can not see anything burnt out inside, all fuses ok. Gave it to someone who dose electrical work but they cant see whats wrong, he said having a wiring would be helpfull. Can you help ? regards ****.
  • 4,234 Answers
The output section has a problem and the amp is in protect mode. This unit needs service. Expect parts cost arounf $30-$50 plus the local labor rate.
Dan
Posted on Apr 11, 2008
Hi. I recently installed 1.5 T, 3 * Split AC, LG. Whole day the AC works fine and no problem in cooling too. But once in 2 day outdoor unit start making thudding noise continously and does not stop for 4...
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Apr 08, 2011 | LG Heating & Cooling
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 05, 2011 | LG DLG5988 Gas Dryer
Both fuses burnt and both clip and signal led on? seems to have full power behringer ep2500
Suspect an overload in either the power supply section or the devices on the main heat sink. In the power supply you are either looking at a transformer problem or semi-conductors associated with it. However since the clip and signal lights are on, I would go to the amp devices on the heat sink. If they are transistors test them with a Ohm Meter on the 1K setting in circuit even! You will soon notice which ones are gone! The meter will show like you had touch the test probes together!
May 15, 2010 | Behringer EUROPOWER EP2500 Amplifier
What is the best level to set the gain
Try to set the gains at about half throughout a system. This is for best signal to noise ratio.
Be careful with these powerful amps that your speakers are rated above what these amps can deliver.
May 07, 2010 | Behringer EUROPOWER EP2500 Amplifier
The fuses have blown due to a short circuit, ie some part acting like it was a piece of wire. The chances are (with the LED's showing) it's the main amp semiconductors (on the heatsink) that have gone. The cause is either connecting a wrong (unsuitable) speaker(s) for the job, or letting the two wires (to each speaker) touch each other.
Mar 28, 2010 | Behringer EUROPOWER EP2500 Amplifier
Does anyone has overheat problem with Behrigher EP2500 power amplifier? We had the amp for abut a year. The amp. has recently become overheat (hand burning) after 30 minutes operation. We set the gain to...
The last time I had a problem like this there was a defective transistor in the from end that was generating noise in the 30K range. Too high to hear and too high for the speakers to reproduce, but enough to put quite a load on the amp. Does this occur even with no speakers attached? If so, then put an osciloscope on the outputs and look for signals. WIth no input, there should be no output at all except for a little noise. You can also see if there is any DC on the outputs as well.
Please update this with what you find.
Thanks,
Dan
Oct 13, 2009 | Behringer EUROPOWER EP2500 Amplifier
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Thud noise / jolt when transmission.......
Yes, I would get the transmission checked it sounds like it maybe getting ready to go out. Take the dipstick out & smell the fluid to see if it smells burnt...Hope this helps..
Jerry
Jul 23, 2009 | 1983 Toyota Land Cruiser
Infocus X1a LONG startup times
Sounds like the power supply is weak if it has to run for awhile before it functions. The control board could also be the issue. Does it make any grinding or buzzing noises?
Jul 18, 2009 | InFocus Televison & Video
Bass problem
You're getting some sort of capacitor discharge noise on your signal. There's no easy fix for that. It will have to be taken in for service.
Mar 16, 2008 | JVC RV-B90 Boombox
Behringer EUROPOWER EP2500 Amplifier Logo
119 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
