Question about MSI MS-6390 (-6390-010) Motherboard
USB Hi there, I was wondering if anyone could help me with a small issue please? I just transferred my motherboard into a new case from its original and I'm not sure how to set up the USB power cables for the USB that came with the new case. Any suggestions or maybe pointing me to a manual would be much appricated <3
  • Ruffshod Apr 11, 2008
    Sorry..im too stupid to understand this :(
  • 53 Answers
Hi
P l do this
          1  2 3  4  5
          1  2  3  4
Before connected to pins u first see which  is  the first pin
H ere 1 is  connectect  to USB+5V (Red color)
         2      "                 to  USB _2
        3     "                   to USB +2
       4  "                       to GND
Here  -2& +2 or varies depending on ur port number
Second side also connected in the same manner
Regards
Was this soultion useful ? show ur appericiaation by rating it
Posted on Apr 11, 2008
Samsung galaxy 3 mtp fail
i remember having a similar issue with my Note (original) a few years back, it was something to do with the phone settings, i had to put the device into USB mode for it to connect and transfer files.
Hope that helps.
Nov 16, 2017 | Samsung Galaxy S III - Pebble Blue...
Hi I want to transfer the parts in my Acer Aspire M5640 but I'm still new to this and I am not sure if its motherboard is able to fit into any kind of case. I mainly want to change cases in order to...
Desktop cases have standard mounting holes that allow you to fit a range of motherboards.
I do volunteer work and setup and repair computers and have not found problems fitting motherboards in desktop cases, except in some small format brand name computers such as HP and IBM computers.
Apr 28, 2011 | Acer Aspire m5640 PC Desktop
I had a friend transfer my computer components eg. motherboard, HDD, Ram etc, from a ugly computer case to a nice looking one, she got as far as screwing in the motherboard and hooking the HDD...
Hi:
To solve your puzzle, you need to find the manual for your motherboard. If you don't have it still, almost all of them are available online at the manufacturer's support website. The manual always has the pin out diagram for the motherboard, and from there its just a matter of plugging the small connections together. Remember that connections for LED lights have polarity, meaning that they need hooked up one particular direction for the light to work, but any switch connection doesnt matter.
Hope this helps
Oct 22, 2010 | Computers & Internet
Connection of wiring to board
6a98a1a.jpg For the usb connectors you can follow the diagram above:
For the rest of the connectors I need to know the model number of your motherboard
Nov 23, 2008 | Computers & Internet
This device can perform faster
Hi there :)
I'm no expert, and don't profess to have the answer, but if a device is performing tat USB 2 capacity then suddenly doesn't, and another device performs at USB 2 capacity on the same port, then there has to be an issue with the problem device itself, or possibly an update may have caused a specific, device related incompatibilty issue.
I had the same USB problem on a 2.5 External drive a while back, it also would suddenly shut down during transfer for no apparent reason, I replaced the case and problem solved, it goes like the clappers!!!! Clearly it was something to do with the old enclosure itself.
At the moment, I've suddenly developed the same problem with a 500gb External that up until now has been working absolutely fine. All my other External Drives, a couple 250gb and a couple 350gb, are IDE while this is a SATA, but I don't really think that's either here nor there, as the 2.5 I had issues with is IDE.
This case is under warranty so I've sent it back for testing.
I've spent hours looking for answers, and can't help but wonder if in some cases a lack of power, or loose connection is the issue. The only real difference between my Externals is the actual setups. I wonder if maybe, with plugging and unplugging, they get a bit worn over time, and simply fail to connect correctly.
My old External drives, a couple 8 years old, have solid aluminium cases, with the drives screwed firmly into place as in a desktop. They're solid as a rock, and haven't missed a beat. There's plenty of cord between the devices and adapters, so there's no drag on the connections.
On the other hand, my problem external has no screws, just sort of keepers that are supposed to hold it in place, but don't in fact. There's quite some space between it and the other end of the case/enclosure, certainly it's no snug fit, the drive inside has some movement, so that there's a certain amount of give when you plug into the interface. Also, there's very little length between the adapter and device, I have to be careful where I put it to maintain a good connection Similarly, my problem 2.5 originally had no screws either, just makes me wonder.
No real answers sorry, but some of it may help point someone in the right direction.
It really is quite a frustrating problem just the same :)
Good luck all
Mel
Sep 08, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
New Motherboard=no printer
Hi I am back again. I wanted to see if you reformatted your computer after you installed your new motherboard. If you did not , you had better do so, because installing a new motherboard and not formatting your computer first can cause a lot of problems and cause the activation status of Windows to quickly get lost.
Did the motherboard you replace come from a brand name computer? If it did , it most likely came with its own version of Windows and it is tied to the motherboard meaning you will have to buy a new license for your new motherboard. OEM software is tied to the original BIOS it was activated on at the time and is non transferable to a new motherboard. You can plea to Microsoft all you want but they wont budge :)
Aug 16, 2008 | Dell Dimension 8300 PC Desktop
This link will take you to the download page first download is bios second is manual
Mar 29, 2008 | VIA Jetway V4MDMP MB AMD SKTA MATX/ KM400/...
W2562 Mobo
Your best bet would be to try to trace the pinout using the faulty Dell case. It's extremely unlikely that anyone has done a wiremap for this. Sorry, realize this isn't the answer you're looking for, but is a suggestion.
Sep 12, 2007 | Dell (W2562) Motherboard
MSI MS-6390 (-6390-010) Motherboard Logo
96 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
