Question about Brother MFC-5440CN All-In-One InkJet Printer
OCR with Brother MFC 5440CN
I'm trying to OCR with my Brother MFC printer (5440CN). The printer responds with a "No OCR program installed" message, while ReadIris is installed on my winxp pro system.
How can I set my printer to recognize my OCR program?
  • 6 more comments
  • chermesh Apr 11, 2008
    Thanks Mix-it-up,
    When I hit the OCR on the CC2 all I get is the following error message:
    This feature is not available because there is no OCR software installed. Please install the OCR software.
    At present, two, and not solely ReadIris, programs are installed. I added Omnipage, and still get the same error message.
    As to PaperPort, I've uninstalled since it is a much too much heavy application for my purposes.
  • chermesh Apr 12, 2008
    The Brother Control Center doesn't allow me to set ReadIris as my OCR program. When I look for a list of optional programs, the list is empty.
    Any idea why?
    Mix-it-up, your suggestion looked like THE most effective one. I checked the Brother KB and reached http://welcome.solutions.brother.com/BSC... (When scanning to OCR from Brother Control Center 2.0, the OCR application doesn't launch. I have Windows® XP Service Pack 2 (SP2) installed. What should I do? ). This document deals EXACTLY with my problem. I followed the instructions, but the problem is still unsolved. (One minor difference between my system and the one referred to in the documents is that my is the beta version of SP3 while the document deals with SP2).
  • chermesh Apr 13, 2008
    Well, I'm still stuck. I checked the documentation on the installation cd, but found no useful reference to OCR. I called the Brother -Israel support, and was told that OCR service is quite meager on MFC-5440CN and that it's tuned towards the Omnipage driver which is part of the PaperPort package. I'm not sure the information is dependeble, but if it is, then it's almost a cheat!
    Could you offer any further ideas?
  • Anonymous Jun 26, 2008
    "this feature is not available because there is no OCR software installed. Please install the OCR software first. (CC3-108-00031109)"
    I am running Vista Home edition and my printer is a Brother MFC - 240C.
    I get the same message above. I visited http://solutions.brother.com to search for the software but did not find it. Where can I download this OCR software. Or is it that MFC 240C was not built to run on Vista?.
  • walayoade Dec 02, 2008
    I cannot scan to OCR, the message is install OCR software first, how can I install OCR software, I use Brother MFC-5440CN with windows XP
  • henrycole Mar 08, 2009
    I am having the same problem plus I can't open CP2
  • Anonymous Mar 14, 2014
    MFC 7220
Abbyy finereader 6 works well with the 5440cn. The latest version is 9.
Posted on Apr 24, 2008
Unable to clean troble shut Maintenance
Posted on Oct 05, 2010
  • 832 Answers
You can program by help of the brother control center. open cc and set readiris as the ocr prog. (actually the paperport prog has a built-in ocr engine)
Posted on Apr 11, 2008
  • Mix-it-up
    Mix-it-up Apr 12, 2008
    do run the cc2 update and read the software manual which is part of the installation cd! And have a look at the faq, too:
    http://welcome.solutions.brother.com/bsc...
  • pamela00 Dec 13, 2010
    There is no ability to choose software from the drop-down list in the control center: OCR options. I go to 'configuration', then OCR, then to the drop-down menu, and even though I installed Readiris as you recommended, I am unable to select it, it is not there. I will restart everything, but please do send me better instructions, thanks! Pamela
Hi I have a brother mfc 5440cn and it fails to print but comes up with an error 50 message. How can i solve this?
Where does the Error message appear? is it on the printer or the PC.
Try a test print from the printer menu
Press Ink
Press up or down to select 'Test Print'
Press up or down to select 'Alignment
Press menu/set
press black start or colour start
The printer should start printing. If this prints ok then the problem is likely to be with the comms between the printer and workstation
Sep 02, 2011 | Brother MFC-5440CN All-In-One InkJet...
My printer OCR command does not respond. The printer says it's connecting to the PC but after a short period reverts to standby.
  1. faq000559_002 When I try to OCR into WordPad using the ScanSoft® PaperPort® SE with OCR or the Brother ControlCenter3, the text comes out as gibberish. This started after I installed Windows® XP Service Pack 2 (SP2). Why and what should I do?
  2. faq000093_012 What is MFL-Pro Suite Software?
  3. faq002613_000 When I try to scan to OCR I get an error message saying "This feature is not available because there is no OCR Software installed".
  4. faq002561_000 How do I configure or change the settings of the ControlCenter 2 or 3 scanning options?
  5. faq000562_002 When scanning to OCR from Brother Control Center3, the OCR application doesn't launch. I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  6. faq000563_002 When scanning to OCR from PaperPort® SE, the following error message appears: "System error incurred in external ink module EZText.g32. The OCR server is unable to process the document". I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  7. faq002620_008 Windows® 7 Support Information
Oct 26, 2010 | Brother DCP-330C All-In-One InkJet Printer
I am getting the unable to print Error 4F message on my Brother MFC 5440cn printer
Error 4F:
The head drive voltage has
dropped from the high to
low level in an abnormally
short period.
Piezoelectric (PZT)
ceramic actuator
defective
You need to replace the print head.
Oct 06, 2009 | Brother MFC-5440CN All-In-One InkJet...
Using Windows vista and MFC-440CN for scanning
The OCR software comes with the printer on installation CD's .. otherwise goto HERE
Select all
Select WIndows Vista
Select English (or whatever language you want)
Click Search
Download and install the vista programs/drivers
Dec 01, 2008 | Brother MFC-5440CN All-In-One InkJet...
Not printing
i have a brother mfc 5440cn printer,error message says out of black ink,i replaced it,still says out of ink,i opened and checked micro switch,then bypassed micro switch,still reads out of black ink and wont go any further than that
Sep 29, 2008 | Brother MFC-5440CN All-In-One InkJet...
Model MFC-7420 Scanner problem
OCR program, a program that reconises what characters you have scanned from a original... I do beleive that the brother software package that comes with these printers has one included, go to brother web site and download full driver and software package for your machine
The ocr program that comes with your machine is called
ControlCenter2.0
link to brother site download US
http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/monolasermfc/mfc7420_all.html?reg=us&c=us&lang=en&prod=mfc7420_all
Oct 30, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
26,770 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
