Inspect the lamp on your fax machine to see if it is working properly.
Fax machine may be able to send but may not be able to receive to print out files if the bulb is burned.
Check the lamp to see if it is the cause of the problem.
Take care.
First thing that you need to make sure here if they are using the right phone line cable, make sure they use the cable that came with the unit and also doing a uninstallation and re installation of software will be good thing to do and follow the steps there to reconfigure the fax.
need a better solution the phone line is fine, and so is the cable
the fax picks up from a regular fax machine but when people send through efax electronic files it says it receiving but never actually prints out the fax
