Question about SanDisk Sansa m200 SDMX3-512 MP3 Player
Connection problem Yesterday I purchased a Sansa e200 and tried to connect it onto my PC. However my even though I hear connection sound, the Sansa player will not appear on my computer. I think the problem exists in my computer because it did worked fine with my friend?s computer. Regards, Isaac
    Genius:
  • 1,224 Answers
Its the usb connection you probably connected to hub with bad usb port or needed update usb parameter port
Posted on May 09, 2008
Volume
Hello john
Have you tryed reseting the device?
Il get you instructions in a moment if you havent.
May 07, 2008 | SanDisk Sansa e200 MP3 Player
NO AVAILABLE PLAYER DETECTED!
Try going into settings, usb mode change that it should be either mtp or msc.
May 09, 2009 | SanDisk Sansa e200 MP3 Player
Sansa e200
There is one option, not really a fix, just a workaround. Try the player on a different computer computer and see if it is recognnised there. If it is, then use something like a pen drive to transfer music from the PC that doesnt recognise the device to another that does. Now you can transfer music using the WMPlayer sync service.
If your device is not being recognised on many computers, it looks like it is time to chuck it away. You can also try this first though..
1. Remove the player from the PC and switch it off.
2. Restart the computer.
3. Hold the +Volume button and connect to computer.
4. Keep the button pressed for at least 60 secs, and you should see the "Found New Hardware" balloon pop up, indicating that the device has been detected.
If even that fails, then I'm afraid your Sansa player has run its course, and you may need to purchase a new player...:(
Jun 27, 2008 | SanDisk Sansa e200 MP3 Player
Volume
Dumb me. I should have read the manual first, instead of just glancing through it.
You just turn the thumbwheel to adjust the volume.
imjohn
May 06, 2008 | SanDisk Sansa e200 MP3 Player
IT TOOK MY MEMORY!
have you deleted the partial video, if not......
1. connect the sansa to your computer,
2. select open device with windows explorer,
3. click on the drive where the video content is stored,
4. click on the video folder, then right click on and delete the video,
the path,
My Computer/Sansa e200/SELECTED DRIVE/video
May 05, 2008 | SanDisk Sansa e200 MP3 Player
No Drive on Connection
Hi, When i connect my sansa e200 mp3 player with my computer..it showing CONNECTED on the mp3 player screen, but does not show any disk drive in my computer. No problem with computer, my pen drive is working fine with it. can someone help?
Dec 08, 2007 | SanDisk Sansa e200 MP3 Player
"unknown" songs taking up memory in my sansa e200
Renew music svc sub, convert to Mp3, or update/remove DRM licensing
Nov 25, 2007 | SanDisk Sansa e200 MP3 Player
Sound Only Comes Out Of The Right Earphone
If its less than 1 year old, have it replaced. Its a loose connection on the circuit board. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 24, 2007 | SanDisk Sansa e200 MP3 Player
Battery Recharge
"Removable drive" sounds like it got set back to MTC mode (USB mode in sansa settings menu). Needs to be in MTP mode to really be of any use. I have the e280 and it recharges fine when it's hooked up to my PC. It might be the battery, the connection, or the player. Also, it has to be a "high power" USB port on your PC (whatever that is). ie: If you're on a really old PC, there might not be enough juice getting through to the player. But if the rechargers don't work either.....
Dec 01, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m200 SDMX3-512 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
