Question about Samsung Napster YH-920 MP3 Player
Cannot initialise HDD
HI,
I was using my player fine ..
but all of a sudden the display got frozen in the playlist but the HDD was still running, ii was unable to switch it off . The battery drained out and the player switched off
But after i recharged the player and tried switching it ON , it reads the msg sayin "Device cant initialise HDD,please connect to adaptor and try again ",
i tried connecting to adaptor and restarting , but of no use. please help me with this .
Thanks in advance,
rakesh
Thanks a lot computer rep.... will try doin this and let you know.... Speaking about the reset button on the player . i already tried it but it was of no use... i have to take out the battery and see on ce... If possible can you point me to some location whre i can see the inner parts of the player before i dismantle it . ? it would be of great help .
Posted on Apr 13, 2008
  • Catherine Scott
    Catherine Scott Apr 14, 2011
    Just used this advice 3 years after you posted it and it worked, thanks so much!
  • 758 Answers
First of all, of course, try to repair it by using the recovery utility softwear (you know, pressing >> Forward while connecting the switched off device to the usb). If it doesn`t help, read further---> The problem is that simply an error in the softwear of the device occures. Normally, this could be fixed by restarting, by pressing the RESTART button on the back. BUT, by pressing it, you don`t actually restart the hole device.Certain commands are still running in the processor and this cannot be canceled until there is the slightest electricity in the battery left. That`s why I open the player, safely and very carefully remove the Hard Disc, than reattach the battery, so that no electricity is left. Then, connect the battery again, place the HDD again on its place (carefully please), watch out that it connects to the motherboard, and close the hole player.
By switching it on, there should occur no problems. But I recommend using the RECOVERY UTILITY softwear for repairing the hard drive, as well as rebuilding the library and probably formating (hear you will lose all data). Note that it is best to have the song titles written on latein (english), cyrillic for example is not recommended.
If that doesnt fix it follow the steps bellow.
1. Make sure player is off.
2. Take off back cover. 4 tiny screws.
3. Take out the HDD, the big rectangle thing. The back of it should be silver.
4. When you take it out, the front should have a "gold sheet" attached to it.
5. At the lower corner the "gold sheet" is a cut out part. This "cut out" part is where the HDD connects to the "mother board".
6. Bend that piece ever so slightly where u can place your finger between it and the HDD.
7. You will then plug in that "male" part to the "female" part on the mother board.
8. when you feel it snug or snap, your MP3 should work now.
9. turn on the mp3 player to make sure it loads.
10. if it does, then you have fixed your "problem"
11. reassemble player accordingly.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on Apr 12, 2008
Sansa e260 installed with rockbox doesnt play video.
Sans e200 support:
http://www.sansa.com/support/sansa_e200/faqs
Manual for Sansa e200 series:
http://www.sansa.com/sites/default/files/downloads/e200_userguide_en.pdf
1. Using the Sansa media converter for preparing videos to make them
suited for the player as you are doing is just fine.
2. Page 22 [19 in written manual] of the pdf file shows how to make playlist(s) using Windows Media Player 11.
2.1 First create a playlist
2.2 Save the playlist
2.3 Synchronize the required playlist onto the connected player
Sep 09, 2009 | SanDisk Sansa e260 MP3 Player
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
Display blinks
I do have samsung mobile E250, It's display suddenly turns blank while and not clear picture taking photos,
Apr 03, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
My pc hard disc not initialised and no monitor display
kindly check your HDD's IDE if it is properly connected to your motherboard or better yet check your BIOS booting sys. use default booting sys.
Jul 23, 2008 | SanDisk Sansa m230 MP3 Player
LG RH265 - Problem when trying to register blank disk/dubbing
The DVD needs to initialise the disk first. Come out of the HDD dubbing menu and press DVD on the remote. The blank recordable disk should be recognised and you should see Initialise disk? on the screen. Press Start and hey presto, you can now dub from the HDD Movie dubbing menu (as per the manual instructions).
Feb 15, 2008 | LG RH177 DVD Recorder/HDD Recorder
Toshiba RD850-T Error Message14
try hitting the diplay key (couple of times/rebooting) Solved the problem for me...
Jan 21, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
IRiver H10 20 GB
Hi Vera I am using windows2000 OS, can not yet justify a faster Pc to run XP .. following is what I use to load and manage my MP3 audio files on my H10 20GB >using an alternative to WMP 10, I use 'EasyH10' .. prepares an H10 player without iriver plus or Windows Media Player 10 based on music and playlist files transferred manually using windows Explorer easyh10-15.exe Info re Easy_H10 URL http://www.misticriver.net/wiki/index.php/Easy_H10 URL http://sourceforge.net/project/showfiles.php?group_id=138812&package_id=152796 download 'easyh10-1.5_win32gui.zip' - connect USB cable between Pc and H10 - place H10 in 'Lock' position - use a tool ( refashioned paper clip ) to press the reset button - start H10 in USB Mass Storage Device Mode... Hold down 'O' button, continue holding 'O' button while you press the 'On / Off ' button until screen displays USB connection, after emergency display - In Windows Explorer locate the ' removable drive' - Transfer your music files with tag information to 'Music' directory on H10 - Run EasyH10 - for Media database construction to display songs in MUSIC mode. - Playlist conversion, a necessary process for your playlist files to become compatible (recognizable) with an H10 player. - EasyH10 also imports/exports tuner presets from/to a text file. Prh
Mar 18, 2007 | iRiver H10 MP3 Player
Samsung Napster YH-920 MP3 Player Logo
264 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
