Question about HP Pavilion dv4000 Notebook
Modem hi, i wanted to connect to the internet the other day, but it wont connect me. However it says that your Modem is not connected. So i tried to look for my modem cd, so i can reinstall it, but i cant find my cd. My lap top is HP Pavillion, dv4000. i really need this problem to get fixed, coz i have a report due monday, and i need to find literature. can anyone please help me. thanks
    Genius:
  • 2,785 Answers
Please check the manufacture website
Posted on Apr 11, 2008
I can get my playstation network online with my hughes net HN9000 modem but it wont join any games.Is there anything you can do to get to play online with a ps3?
You may have a weak internet connection or the playstation network/ game servers may be down. Make sure you have updated your ps3 to rule out that possiblity. You may want to try going to settings>network settings> internet connection test. If you have a weak signal strength, you may want to try moving the modem closer/ point it closer to the ps3. My download speed shows 2.1Mbps and upload 647kbps which is fairly average and don't usually have a problem. I find that sometimes I cannot connect due to the time of day (too many users onlie at the same time in your area may slow down your internet speed), for this reason I always have more luck playing later at night or earlier in the morning which may or may not be an option for you. Hope this helps!
Jul 28, 2011 | Video Game Consoles & Games
I have no internetconnection with my ps3. I have error 80028ea6 Who can help me?
Good day. If your ps3 is not connecting to the internet. Try to do this steps:
1. Check all of the wire and cable from modem to router.
2. Make sure all cables are tight
3. Try to reboot your equipment on this sequence, modem - router - ps3
If these didn't resolve your issue you need to contact your Internet Service Provider to check your connection. Possible the modem is not getting any signal. If your modem is working good then contact the router support to check the settings with your router. But usually your Internet Service Provider will be able to resolve this issues. Hope this information will help you in resolving your connection problem. Have a great day and thanks for using Fixya.
Jun 23, 2011 | Computers & Internet
After connecting modem to pc, the link light in modem was orange, the others were all green, of course, pc can not surf internet. Try to restart and change modem location, issue persists
Good day.You can do the following to make your connection work.
1. You need to make sure that the cable connection between your modem and wall outlet is tight.
2. Ethernet cable should be detected when plugged in to your pc ( usually a pop up on your screen will tell that)
3. Link light means there's a conenction between your pc and cable modem.
4. You might need to check if the online light or cable light on the modem is on to make sure that your modem is getting a signal from your cable internet provider. If its off you need to contact your internet provider because there could be an issue or possible outage on your line.
5. You can also try to restart your computer once its connected to the modem to refresh the ip address of your pc.
6 You can also contact the tech support number for your internet provider for them to diagnose the issue.
Hope this information will help resolve you're problem. Have a great day and thanks for using Fixya.
Jun 11, 2011 | Arris SURFboard SB5120 Modem
Sir when i am connect my nokia2626 mobile phone to pc via nokia pc suit when it's not work correctly and the main proble is that when i want to connect my pc to internet using my phone then message shows...
Hi!
You have to select the mode of connection.. through blutooth or by usb data cable.
If by blutooth, you have to stable the pairing of the phone and the pc.. You also need to make sure that your phone has already the settings that your phone provider has sent you to access by phone.. If you can access the net from your phone then its ok to surf internet on your pc via phone as your model.
You also will need to set your phone as your modem.. how? go to control panel and select Phone and Modem, there set up the phone as modem.
If this things are done, then go with your pc suit again and try connecting.
If you are trying to connect via usb data cable.. you will need first to install the driver of your cable before you can start pairing your phone to your pc via pc suit.
I hope i gave you a better idea with that.
Much appreciated if you could rate this help. Thanks
May 19, 2010 | Computers & Internet
Dell TrueMobile 2300 Router wont connect to My cable modem
You are most likely making a mistake in the setup instructions.
Jun 20, 2017 | Computers & Internet
Westall modem taking 5 min to connect to internet to (AT&T DSL)
its your connection which is the problem plz try complaining on help line of you connection
Aug 27, 2009 | AT&T High Speed DSL Modem
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Connection to x box live recken my head
two things, if you're using a wireless modem, unplug it from console, re-set it and let it connect and sit for a minute. then plug it back into the console. if you have just a regular modem do the same thing. make sure the wire connecting you're box to the modem isn't too long(over 7feet is too long). it wont update if you're not connected to the internet.
Feb 19, 2009 | Microsoft Xbox 360 Console
Connectivity problem
it is still trying to connect via your modem, go to control panel>network connection, and you will see your modem dialup connection, right click and select dissable if required.
next open up internet explorer, go to tools>internet options, then click on connections tab, then half way down select 'never dial a connection'.
Click apply>ok, then close internet explorer, open it up again and wait a few seconds and it will connect via your router(asuming that it is correctly set up).
If no page appears then click refresh a few times.
Aug 12, 2008 | Acer Aspire 5100 Notebook
My connection fall
Please describe the leds in front of the modem which led lights or blinking ?
Aug 17, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
HP Pavilion dv4000 Notebook Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
