Question about Sony Ericsson K750i Cellular Phone
Camera Problem, Need HELP...
Hi, I've a SE K750i handset that has a camera problem. The camera displays a black screen without any image even on opening the shutter and when I try to click with the blank screen, the auto focus keeps adjusting without any picture displaying on the screen. Neither does any picture get saved on the camera. Can u Plz HELP !!!
  • 2 more comments
  • afianti se Apr 14, 2008
    i have a problem with my SE K750i the camera can,t be open. if i open it the camera just flick in a second "sorry my english it,s very bad"
  • Abbbi Apr 20, 2008
    HI
    I HAVE A SE K750i .WHEN I OPEN MY CAMERA'S SHUTTER IT'S ASKING ME TO OPEN THE LENS COVER.EVEN IF IT IS OPENED AND CLOSED SEVERAL TIMES
  • Anonymous Apr 24, 2008
    i have a 750i.my still photo canot be saved but my video camara work properly
    pls give a solu my mail id is vipinkvarghese@yahoo.com
  • alenjoesph Dec 26, 2008
    I am using SE K750i, I cant able to capture picture,when i click the cam button, first come with white color square follow with a green color square with little sound....Picture cant saved.....
    Pls help me alenjoesph@gmail.com
  • 3 Answers
just format your phone memory and memory card through your pc.
this is the solution ... How to do!!
Copy your all files from memory card and phone memory to your hard disc and format both of them.........
Now start your camera, select destination - first the phone memory, click one photo. Then your memory card, and click. This is just to create folder through mobile. Now try to play song to create folder.
Now!! paste your files to the folder created on your phone and Mem card, and don't past the folder. If you need folder then create new one.
Your Phone will be OK now !!!!!!!!!!!
Posted on Apr 20, 2008
Hi sir i have s k750i phone ;last day i given my phone to change my phon`s central body ;and it is changed but volume key do not work properly hence they replace it by privous body then all key work properly;BUT my still camara take picture But do not save picture on phone just escape from camara menu to front screen(falsh sound &auto focus&video camara are work properly).I show my phone on sony eri auth service centre they told that it is a software problem they update my phone software but the problem is still exist they sujest that it may be due to flex. pls sujest a proper solutino immediatly tanku sir
Posted on Apr 12, 2008
Hi friend. better u try to flash your mobile with R1CA021 firmware
Posted on Apr 11, 2008
2 Suggested Answers
vyas
  • 36 Answers
SOURCE: SE k750i Cam problem. Pics not getting saved. Plz..HELP
follow the instruction as said by gizmo11
Posted on Oct 16, 2007
My cannon powershot sd 1000 camera stays black on the screen all of the time, I tried pressing the display button again and it did not work the shutters in the front seem to be working just fine. last time...
If the menus come on but there is no video or picture from the lens, that is usually the CCD which is a sensor in the camera that picks up the image. If you need to have it fixed, it's only $79 total for the parts, labor, the servicing for the camera included and even the shipping back. Go to: www.CamerasAndParts.com They just service these Canon Powershots exclusively and they are excellent for service on these. Your exact issue is on their site, it's $79 for everything and they do superb work on these models. I hope that helps, good luck with the problem.
Jun 14, 2011 | Canon PowerShot SD1000 Digital Camera
SONY DSC-T1 CAMERA WHEN TURNED ON PREVIOS PICTURE SHOW UP FINE ON THE VIEW SCREEN BUT WHEN THE THE SELECT MODE SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO MOVIE MODE THE VIEW SCREEN IS MOSTALLY...
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
Mar 01, 2011 | Cameras
Can I export images from iPhoto back onto the camera?
Yes, by using a card reader (despite the name, a card reader is also a card writer). However, if you've done any editing on the image (even simply opening it and then resaving it without making any changes) there's a good chance the camera won't display it.
Dec 23, 2010 | Canon PowerShot SD1100 IS Digital Camera
Canon Power Shot A710 is
The hand with parenthesis is your image stabilization. It sounds like if your images are turning out black, you may need service.
Try hitting your display button a few times and see if anything shows up on the screen.
May 29, 2008 | Canon PowerShot A710 IS Digital Camera
Problem in taking snaps & videos
My SE K750i handset has been fallen down from a height of 6ft. It got switched off. and was working well when I started except the camera. even after opening the shutter its not displaying the camera its only showing the wallpaper. Not even from camera menu. So I can't take any snap or video. Please help me as what to do . some times when i am going to the menu it is hanging.authorised dealer told that it has virus.please help to solve this problem
May 20, 2008 | Sony Ericsson K750i Cellular Phone
No display at all. But able to take pictures with Canon A75
Sounds like you might have accidentally turned the display off. Turn on the camera and press the DISP button once on the back of your camera.
Mar 17, 2008 | Canon PowerShot A75 Digital Camera
K750i Problem
camera pictures not didply on screen and wallpaper not set all stored photos are currepted
Dec 13, 2007 | Sony Ericsson K750i Cellular Phone
Broken camera
I took my Back of my k750i to put a new cover and back on and now the camera is not working. THe phone is not picking it up. I think theres a connection at the back but i cant find it! plz help.
Jun 19, 2006 | Sony Ericsson HBH-610a (Auto Pairing)...
Sony Ericsson K750i Cellular Phone Logo
216 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
