Need to find info/pricing for Xerox 5334 copy machine.
I inherited a large copy machine from someone who got it from his work a couple years ago. I have no idea how much it originally cost and can't find any info on it like how old it is or what it sells for nowadays.
I need to sell this thing as I'm in a bind and need money. Can someone point me in the right direction or give me an educated guesstimate?
It makes 32 copies per minute and can handle 30,000 copies a month. It's digital black & white, can be networked and has features such as binding, stapling and 3 hole punching. I think it cost around $5,000 originally.
Thanks for any help!! Holly
    President:
  • 2,072 Answers
A 5334 is a pretty old analogue machine.
I would say selling price would be $500 or less
The machine pictured can not be networked.
Posted on Apr 11, 2008
  • Rick Kasper Apr 11, 2008
    That is probably 15 years old by the way, I forgot to answer that part of your question.
    Wish it were worth more for you.
    But thats about where it stands.
?¼?¾?¶?µ???Œ ?½?µ????¸ ?½?° ?¿?¾?¼?¾?¹????, ?½?¸???¾?¼?? ????¾ ????°???Œ?µ ?½?µ ?½???¶?½?¾.
Posted on Apr 15, 2010
I needed a new drum (j2 error) so I bought one, installed it correctly, but the machine still shows the j2 error and will not clear itself or let me make copies. What can I do? I really need it to be...
Found old post for diffrent printer see if this info helps.
Drums may worj the same even though diffrent models.
Problem with the Xerox Printers Xerox XD130DF J2 error replace
By lgrey on Jun 20, 2008
Xerox XD130DF J2 error replace drum Best Solution posted 3 years ago
cbb7438.jpg rytech uk
  • Rank: Wiz computers_small.png
  • Rating: 80%, 98 Votes
Im presuming that your have replaced the drum??
if so :
Remove the new drum.
On the front of that drum, there is a green cover. Take it off and what has happened is the flag on the gear had dropped in shipping.
You will see a flag like piece of plastic on one of the gears, reset it to up and somewhat to the right.
Then put the green cover back on
That flag has to be in the up position when new. It passes down and actuates a drum reset switch on the machine.
When that is back in the up position. re insert the drum and on the first revolution it will turn on the switch.
Jul 06, 2011 | Xerox WorkCentre XL2140df Laser Printer
I just received a Xerox 5334 copier. We moved it to our house, powered it up, and ran a test copy (just a sidebar thought...it spit out one copy and a blank paper). I left it on to go retrieve the work I...
Code U4-1 is Over heat or under heat, even if you solve this problem you mentioned that you have a copy from the machine which is Blank, the reason is that the print cartridge is dead, it is not holding charge, and even if you find a new one in a box sealed, I am 99.9 present sure that it is not going to work either, it is an old expired cartridge, basically do not waist your time and money, I serviced these machines and I know.
Mar 23, 2017 | Xerox Office Equipment & Supplies
I wanna xerox machine price plzzzzzz help me
Hi
You can view the pricing of Xerox Machine from below link--
Consolidated Xerox Machine Price List
You can view the prices for almost all Xerox Machines, this list is valid till 30th September 2010.
Daniel Scott
Jun 22, 2010 | Xerox DocuColor 12 Printer
Xerox 5334 service manual
i don't think so because the manual is protected by laptop xerox
Apr 09, 2009 | Xerox 5100 Copier
XEROX C20 - Leaves a blank stripe down the side of the copy
Yeah the c20 is not sturdy at all. But that aside. Some things to do.
1, Unplug the machine, remove the back cover and on the right side you will see the main board.On the top portion of the board you will see a white ribbon cable. Unplug it and look at the silver contacts on the very end of that cable. Then reseat that cable. That may be the problem. More than likely though you have either a dirty mirror in the scanner. Which would require removing and cleaning the scanner thoroughly.
The laser may also need cleaning. The toner cartridges for that machine leave a lot to be desired also. When you get a bad copy remove the toner, shake it from side to side and see if that fixes the problem temporarily. The blades that put the proper amount of ink on the toner roll fail often.
The scanner failing would be my first thought.
Also go to Xerox.com, select support and drivers, then enter C20 in the search box. Then go to drivers and downloads and install the newest firmware for the machine. You may have a machine software issue.
I have worked on that machine since day one of its existence, I never did care for it. It is a cheap machine made by Sharp corporation for Xerox. It really isn't a Xerox product, they just stuck their sticker on it.
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Xerox Phaser 8560DN - WIFI Adapter Has anyone installed one of these? I am looking at a site where you have the option to buy the Xerox Wireless Adapter but does it actually work and are there any...
The Xerox solution works slick but you have to read the directions carefully. I've set these up on a variety of machines, including large Xerox multifunction machines. When configured properly, I was able to do everything including scanning just as if it were a hard-wired connection. However, there are other products on the market that will probably do the same job with easier configuration and lower price.
Feb 18, 2009 | Xerox Phaser 8560DN Laser Printer
I need a scanner that will scan 10X14 pictures
I found some scanners for you listed below but,
You can also scan large pictures in sections, and then use a program like STITCHES. Basically you scan it in quarter sections and then create a working board in your photo program and then you copy and paste each section into that board and line up the edges.
This is what most people do rather than buy a very expensive large format scanner.
Some large companies also have large scanners for maps etc. If you know someone who works for a very large company or one that does surveying etc. They may do this favor for you.
Though copy stores may have the size you need, copywrite issues will be asked about.
Here is the list.
large format scanners http://www.microtekusa.com/lf.html
Microtek ScanMaker 9800XL Scanner
Price: $1,038.31, 12-by-17-inch tabloid size bed
Mustek Scan Express A3 1200 Pro USB Large Format Scanner
$154.69media_size_maximum: A3 (11.7 in x 16.5 in)
http://www.contex.com/english/scanners/sd_series_scanners.aspx
Maximum Scan Width 44in.
http://www.xerox.com/digital-printing/large-format-printers/large-format-scanners/enus.html
Input Size:Min: 4.5" x 5.5" Max: 42" x 100'
Thank you and good luck.
Oct 25, 2008 | HP Computers & Internet
2,724 people viewed this question
k24674
jasbo
jasbo
