Question about Cyberhome CH-DVD 300 DVD Player
Freezing My DVDs keep freezing and skipping scenes. It is not a problem with the discs as it happens with all of them. Is there something I can do to stop this from happening?
  • 472 Answers
How brave are you =)
The easiest way to rectify this will involve a screwdriver, cotton tip (like the ones your wife is always trying to ram into your ears) and a bottle non acetone nail pollish remover. It has to be non acetone.
<<<<<<UNPLUG THE UNIT FOR AT LEAST 10 MINUTES BEFORE PROCEEDING TO ALLOW THE POWER INSIDE TO DISCHARGE>>>>>>>
Open the unit, you will see there is also a cover over top of the dvd drive held in with a few screws, take that off as well to get access to the laser.
Pour a small amount of the nail polish remover into the lid and dip the end of a cotton tip into it (not the whole thing, just a small amount on the tip is fine)
GENTLY clean the laser lens with this. Do not apply a lot of pressure, just enough to make the lens move a little is fine. Clean all over the lens, and make sure to get the top. You can move in any direction.
Allow a minute or so for the cleaner to evaporate, then use the dry end of the cotton tip to jently wipe the laser again.
Pop it all back together and away you go =)
Posted on Apr 11, 2008
My dvd/vcr recorder combo records, but the playback is the problem. I get disc error, or the disks skip and freeze. the problem has only recently started and with recorded dvd's i've played back with no...
If this doesn't happen with regular DvDs you rent or buy, there may be something wrong with the way you're recording DvDs then.
It could also mean the lens head on your DvD reader is dirty
below is a link with instructions on how to clean
http://www.ocmodshop.com/ocmodshop.aspx?a=1225
May 02, 2011 | Philips Magnavox DVD/VCR Dual Player
I Have a Philips CDR820. The problem I have is that the system is "freezing up" and wont play. The troubleshooting manual says to unlug the player for a short time and plug back in. I do this...
What does the display read when this happens, I have experience with these, does it say disc recover? also when the laser reader gets old, it may be done, unless you can maybe find someone with replacement. Old or scratched cds won't read well, or skip also.
Jan 01, 2011 | Philips CDR820 4-Disc CD Recorder
My DVD player keeps freezing and skipping scenes.
Try cleaning the optical pickups you can either take covers off and use isopropyl solution with a clean cloth to clean mirror or you can try a cd/dvd cleaning disc from most electronic retailers.
May 23, 2010 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
The DVR keeps freezing on a frame. When it does,
Usually when a player keeps freezing on a single frame of a dvd, it means that the disc is scratched. When it "sticks", the dvd will usually stop moving (on the part of the disc with a scratch) and the remote will not work. First, look at the dvd and look to see if there is a visible smudge or scratch on the disc. Fingerprints are a common problem with dvds. I suggest you try to clean the dvd in case it is just dirty and if it still doesn't work, some companies make disc repair kits. You could probably find one at walmart or radio shack. These kits repair the scratches in the disc I hope this helps, and good luck! Sincerely, Der Strom
Apr 26, 2010 | Cyberhome DVR 1600 DVD Recorder
Blu-ray freezing
My guess is that the player may need to be cleaned, there is a cleaning kit that can be purchased at an electronics specialty store or retailer such as Wal Mart, if the kit does not correct the problem then you should have the unit checked and repaired or replaced - the unit may be defective. Good luck to you!
Jan 02, 2010 | Samsung BD-P3600 Blu-Ray Player
Every time i play this game it always freezing but when i play my other games they work fine
if its at the same spot all the time then u av a corrupt disc. the only choice you have is to take it back to the shop and exchange for another one. you could also contact the developers and they will sometimes send another disc to you but you have to send the old one back. check on the back of the box for details. if its in a cut scene you can sometimes cancel cut scene and it will be fine.
May 09, 2009 | FROM Software Def Jam: Icon for Xbox 360
Movies are freezing
it depends on the condition of your dvds and how old your player is.
try using a DVD disc cleaner. This cleaner looks just like a disc with some extra little brushes on its surface. Some DVD cleaner kits even come with supplies to clean and modify scratches on your discs. if this dont work you may want to get a new player..
please leave a fixya rating as thats how we get paid...
Apr 26, 2009 | Televison & Video
DVD+RW playback problem(s)
same prob with the shows freezing up
with a DVD+/- RW disc the amout of time keeps dropping because with every recording process the disc loses a life you can burn those disc 200 times before they become useless so the disc might be beyond the life peroid or bad
my prob is with the DVD-/+R disc tho and i figured it out the disc was bad
for the grinding noise if its hi piched its normal thats the disc spinning up to read or write speed
if that not the case something is rubbing in there and that might explaine the writting errors
**DISCLAMER**
the disc manurfacture dose not take resposnablity for defective disc and any loss they have caused(if the data is lost)
Aug 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Cyberhome CH-DVD 300 DVD Player Logo
59 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
