Question about Cameras
Hi, i can view my previously taped videos on my JVC Digital Video Camera GR-D73AA but there is no sound & I can't tape any video as all i can see on my LCD viewer is black. I have already purchased a Head cleaning cassette which hasn't helped what else can i do? At wits end - Many thanks Toni
  • 472 Answers
Hi, If you can view tapes playing back through the camera that were previously recorded using the main flip out LCD then you can be assured the LCD is actually fine. If you can, hook the camera upto a TV and playback the tapes you have to see if you have sound there. If not this will probably be related to the next section.
The problem common to a lot of digital camcorders is the when you try and record there is nothing on the LCD as you describe.
The fault is in the power cuicuit of the lens mechanism. If the lens does not activate, then the LCD will remain black.
The good news is it will more then likely be a micro fuse that has shorted that lets the power through to the lens. Without sound, there is a chance the same fuse powers both circuits.
The micro fuses look like little white strips normally, sometimes as small as 1mm and will be surface mounted.
Camera repair shops will charge quite high amounts to even look at the camera, so if possible call around for quotes, or check if it is still under any form of warranty.
Hope that helps a little anyway.
Posted on Apr 11, 2008
    Master:
    Sergeant:
  • 461 Answers
Seems like you might need to reset the camera. Try this,
Remove
1.0 Any connection from electrical point/PC.
2.0 Remove the battery
Leave your camera for at least 5 min.
Try to restart again....
Transfer movie from mini tape to computer - JVC GR-D770U
install first the bundled software with your camera turned on and plugged in to your pc and then restart your pc if its necessary..
Dec 27, 2007 | JVC Cybercam GR-D200US Mini DV Digital...
I have a JVC video camera modelGR-D290U. I can play and view tapes previously recorded.But when loading a new blank tape the screen does not show what is being recorded and remains blank when rewinding and...
Sounds as though the imager may have failed but make sure you are in video postion instead of memory mode. Little switch behind the lcd screen. Larry's Electronics
Apr 25, 2010 | JVC GR-D290 Mini DV Digital Camcorder
I have a JVC GR-D75OU video camera. When I turn
i have jvc movie camera when i turn it on it says protective cap is on how do i fix this
Nov 30, 2009 | JVC GRD775 / GR-D775US / GR-D775US MiniDV...
Problem lens cap
I had same problem with my gr-d73aa camcorder and jvc fixed it for free because it was manurefactures fault.
Sep 20, 2009 | JVC GR-D73E Mini DV Digital Camcorder
Jvc camcorder
Your camera has failure of the CCD image sensor. Please contact JVC Service for free repair, if your camera model falls in their list.
Aug 19, 2008 | JVC GR-D53 Mini DV Digital Camcorder
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC-GR-D371U
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR D295U
note error codes displayed - if camera shuts off immediately ; if tape is inserted ? put camera to your ear and apply power : if more than one motor sounds ( or sounds ' jerky ' ) your tape may be damaged - no user serviceable options left ; if no tape is inserted ? check with stacy sample at jvc factory service in houston , texas - for possible warranty updates .
Sep 11, 2007 | JVC GR-D295U Mini DV Digital Camcorder
Cameras Logo
69 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
