Question about Casio Parts Cash Register PC Desktop
Changing the paper feeding roller in a cr 110 cash register
How do i change the black rubber paper roller that feeds the paper, with a new one. the old one is broken?
  • 737 Answers
Hi. You buy the feed assembly (the whole black plastic part that holds the roller) from a dealer, then it clips into the back.
Mark
Posted on Jun 23, 2008
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
How do I change register tape on 500dx electronic cash register
There should be instructions where the paper feeds in. Usually, you follow the rollers with the paper and feed it in. Did you try google.com for you instruction manual?
Nov 17, 2014 | Royal 500DX CASH REGISTER
Sam4s cash register
sam 52xxm registers use two thermal printers....so make sure the paper is thermal and not in upside down. also make sure the receipt on/off function is "on" . and finally see if the tubular black paper feed roller hasn't popped out of its socket making the paper not turn or advance
Aug 30, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
I have a Canon PC 980 B&W copier. When I try to print, the "P" (no paper) light comes on, even thoug the paper tray is full.n
YOur problem is likely worn feed rubber. It is an old machine. Has it ever been serviced?
Did this happen after a paper jam?
Try this: UNPLUG the copier Take out the paper tray. Prepare a dry cloth that is dampened with WD 40. Open the door on the right side of the coper. You should see 1 large, gray or black rubber roller. Gently wipe the roller with the WD 40 cloth, slowly turning the roller. It only turns 1 way, towards the exit direction of the paper from the copier.
Let the WD 40 soak in, about 10 minutes. Put the paper tray back in, plug the copier back in and try to make a copy. If it makes a copy, the feed roller needs replaced, If it doesn't make a copy, check the top sheet of paper in the tray. If you see skid marks, you definitely need a feed roller. No, they are not easy to change.
As long as the roller feeds, go for it. When it starts slipping then you'll have to do something about that feed roller.
Jan 24, 2011 | Canon PC-980 Color Copier
I bought a cash register several years ago and never used it. One day, I noticed the big junk in my room so I decided to look and sell.It was the first time I took it out from the box and seemed ...
This is common. If you leave the machine sitting without use for too long, the rubber feed rollers will go out of shape. You need to get the printer serviced now and probably need to have new feed rollers. Alos get the technician to check the battery if your model uses an internal battery.
Oct 20, 2010 | Casio Parts Cash Register PC Desktop
Line feed problems. give 1/2 line feed. document feed sounds like it needs 'oil'
While HP may use a little white grease on some plastic gears, oil is not normally used. Most likely some debris such as paper dust, or part of a label, or a stray staple is jamming the mechanism.
If it's all clean, then I would look closely for a damaged gear of some sort.
Most printers rely on rubber feed rollers of some sort to pick the paper from the paper tray, then more rubber rollers to pull the paper through the mechanism. If the printer is relatively new, the rubber rollers should be in good condition. As the printer ages, these get less rubbery and more slippery, and wear out, leading to feed problems. Further, any contaminant such as oil, white-out, or a sticker on the feed rollers will render them useless. Printer technicians change a lot of these rubber rollers.
Oct 16, 2009 | HP Officejet 7210 All-In-One InkJet...
Cash register will not accept new role of paper, when trying to fix it I must of hit something now the roller won't spin and 'error 94' pops up.
For Casio 110/120/130CR E94 = Printer Problem
Normally there are something "stuck" inside the printer or paper feed assy spoilt.
Jul 10, 2009 | Casio Parts Cash Register PC Desktop
Royal 100nx
Royal wil rebuild that printer, It use to cost $125.00 is it work it. Also many cash register dealers have the part. Most printers are an epson printer and parts are available....
Jun 26, 2008 | Office Equipment & Supplies
Casio cash register model # pcr202
Hi. we don't have that model here, but it sounds like the feed roller has come out. It is common in the little Epson 42 series printers. You will need to get a new feed roller. Some suppliers will only sell you a whole printer - prob around $60-80 US. ring your local dealer and see if one is available.
Mark
Jun 19, 2008 | Casio Parts Cash Register PC Desktop
Paper feed
If the print-out is an 'alien-like' one, the problem is on the sensor of the printer. The sensor is on the opposite side of the gears. Under the black cover.
Oct 11, 2007 | Office Equipment & Supplies
Casio Parts Cash Register PC Desktop Logo
120 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
