Question about Microwave Ovens
The microwave appears to work, but the food is not heating up.
  • ABDUL MAJEED
    ABDUL MAJEED May 11, 2010
    You have not mentioned the model. You can check the fuse at the high voltage output, Check the supply voltage is coming at the primary winding of the highvoltage Transformer. If they are all Ok, change the magnetron.
  • Microwave Ovens Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
My brand new Sunbeam microwave model SGG5701 will not heat. it appears to be working but wont heat food or defrost
Can not find a fuse for a Sunbeam microwave model SGG5701. Where can I find one? My microwave went out after only 3 months of having it.
Aug 15, 2010 | Sunbeam SBM1000 Microwave Oven
Ge microwave digial dispaly works but nothing heats-
in 99% of casses its a burned out magnatron they can be expensive to replace but it depends on how much the microwave is worth
Jun 19, 2010 | General Electric Microwave Oven
Ge spacemaker xl1800
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101][]=--=
May 02, 2010 | GE XL1800 1100 Watts Microwave Oven
My microwave does not warm food!
Likely a magnetron problem that will cost you between $135 and $160 just for the part if searching on-line for replacement.
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker II microwave won't heat what can I do
The main internal component of your microwave oven is called a magnatron. This is the device which generates the microwaves that heat your food up. If your oven appears to be working properly but it's not heating the food, it means the magnatron is not generating microwaves. It could be faulty itself or it could be a component linked to the magnatron. (high voltage capacitor) etc.
Have this component checked by a qualified technician.
Let me know if I can be of any further assistance.
Best wishes,
Graemevm
Apr 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but food does not heat
If everything appears to work as normal but does not heat, then the magnetron will be faulty. This is the device which cooks the food, however this can be an expensive part to replace & may not be economical to fix.
Sep 23, 2009 | General Electric Microwave Oven
MICROWAVE OVEN NOT HEATING UP FOOD
Will need to pull apart to check....common failure with magnatron fuse....but could be magnatron, capaciter, diode. sugg to have a tech look at....if your not able to check, also call manufacturer, sometimes will cover.
Jun 10, 2009 | Microwave Ovens
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
