Canon Pixma iP6600P
Will not print.Tells me printer is offline or failed to print
  • marest Apr 11, 2008
    Done all that,still no go.
  • marest Apr 12, 2008
    Tried all of that.I think maybe the printer needs a factory reset.Can you help?
  • 19,396 Answers
Disconnect usb and reinstall the drivers from disk.
Posted on Apr 11, 2008
  • Ginko
    Ginko Apr 11, 2008
    First try disconnecting printer from computer usb, and disconnecting printer and computer from power cable (if it is a laptop also remove battery).
    You can also try opening the printer cue and deleting all documents in the cue, in case one docunmet is stuck and is blocking the printer. To do so go to installed printer and doubleclick on your printer. This will show the printer cue. Select the documents and chose cancel printing, alternatively select purge printer cue from top bar menu.
    When you open the printer cue check also that printer is not selected offline by user, in menu bar.
    If you cannot solve the problem in the above way you will need to unplug printer from usb.
    Remove printer from 'installed printer' in Windows.
    Reinstall printer software from printer cd.
    Connect back printer only after reinstalling, or when required.
    If all this did not work then your printer may be faulty, in this case you should have an additional diagnostic symptom, for example a blinking red light.
    Regards
  • Ginko
    Ginko Apr 11, 2008
    try a replacement USB cable.
My printer keeps saying it's offline what could be wrong?
Use printer offline setting on the computer maybe checked. For win xp
  1. click on start,printers and faxes then right-click on the Canon Pixma Mp250 printer logo.
  2. if use printer offline has a check mark before it,left-click on it to remove the check mark.
  3. restart printer
  4. try printing again
For win vista
  1. click on start,in the search box,key in printers then hit the enter key on the keyboard.
  2. right-click on the Canon Pixma Mp250 printer logo.
  3. if use printer offline has a check mark before it,left-click on it to remove the check mark.
  4. restart printer
  5. try printing again
For win 7
  1. click on start,in the search box,put in devices and printers,hit enter
  4. restart printer.
Let me know if the steps above do not solve your problem.
Jul 17, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Just set up cannon PIXMA MX870 printer. Cannot get it to print from wireless connection. In my printer box it says the printer is offline. It will print when I connect the printer with a cable. I use a...
I had the same problem - my printer showed that wireless LAN was enabled & my mac showed the printer but said it was offline. I went to preferences, print & fax, hit the + key to add a printer, added the canon printer again, set that printer as my default, did a print command from Word & that created a queue in the new default printer ... and it printed. Deleted the first Canon printer that was "offline." Oh, and I'm not sure if it made a difference, but before what I just described, I checked for software updates after the printer CD install process & uploaded one update.
Jan 27, 2011 | Canon PIXMA MX870 Wireless Office...
Canon ip 1980 offline problem
Saya Punya Printer Canon IP 1980, printer sudah terkonek ke PC driver sudah ok tapi ketika saya print tidak ada respon sama sekali saya cek kabelnya bagus tidak ada masalah . kepada para sahabat saya minta bantuannya dan solusinya ? ...
May 31, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma MP150 offline - won't print from computer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-25
Aug 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I was trying to print using a PIXMA iP1300 but it doesn't allow printing withe a message box appearing "printer is offline".can you help me please
Printer offline : make online in printer properties.Printer offline when start to print : head problem. Replace head.
Jun 12, 2009 | Canon PIXMA iP1300 Printer
1p90 remains offline
i have had a little board inside the machine the connects the usb lead to the logic board fail and this causes this fault. You will need to call out a canon service engineer to fix your problem.
if your in the uk i can give you some contacts .
Hope this helps
Sep 30, 2008 | Canon PIXMA iP90 Mobile Printer
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
100 people viewed this question
jasbo
jasbo
