Question about EliteGroup K7S5A Pro Motherboard
Dell 2400 motherboard and case connections
I bought a new case for my son and moved the old motherboard to the new case but i cant find any info on line on how to wire the individual pins to the pin block any help would be deeply appreciated, thank you very much
I have a bluford e93839-2y mobo
roughneck in michigan
  • roughneck007 Apr 11, 2008
    Hi Markk thanks for helping but if you could steer me to a more detailed diagram ,because the problem is knowing where each connector goes. for example
    power sw blue and white wire
    h.d.d led red and white
    power led + green
    power led - white
    reset sw blue and white and so on, i have also the usb wires to connect the audio and mic wires , i understand the area they go but not the proper pin they actually attach to, im sorry if im not explaining this to well. i hope this makes sense. thank you again for your time.
    Thank you this what i was looking for !! but this is only one part of the puzzle,can you point me in the direction for the pin out header for the usb and the audio blocks ,i still have 2 more ribbions that need to be connected. Thankyou again!
    Genius:
  • 1,027 Answers
Pin Out for header
Posted on Apr 11, 2008
    Sergeant:
  • 221 Answers
Below is a link to the owner's manual for the Dell 2400. On page 55 there is a diagram of the motherboard, and a description of each of the pins. I hope this helps.
http://support.dell.com/support/edocs/systems/dim2400/en/F75560LRs.pdf
  • Mark Kessler Apr 11, 2008
    Pin
    Name
    Cable color
    Description
    VCC
    Red
    +5 VDC
    D-
    White
    Data -
    D+
    Green
    Data +
    GND
    Black
    GroundPin x of mini-USB connector may be not connected, connected to GND or used as attachment identification at some portable devices.
    USB pinout signals
    USB is a serial bus. It uses 4 shielded wires: two for power (+5v & GND) and two for differential data signals (labelled as D+ and D- in pinout). NRZI (Non Return to Zero Invert) encoding scheme used to send data with a sync field to synchronise the host and receiver clocks. In USB data cable Data+ and Data- signals are transmitted on a twisted pair. No termination needed. Half-duplex differential signaling helps to combat the effects of electromagnetic noise on longer lines. Contrary to popular belief, D+ and D- operate together; they are not separate simplex connections.
My son cracked his screen ibought a new one but want to get the info off the old one
Hold the new screen over the old screen and press gently for 60 seconds. When you swap the screen over, the information from the old screen will be on the new one.
Jan 22, 2016 | Irulu 7" 4gb Google Android 2.3...
Cpu upgrade
You can try "support.dell.com".
Jul 03, 2012 | Dell Dimension 2400 PC Desktop
My dell 2400 wil run for sometimes 10 sometimes 45 minutes and the the monitor loses signal and the power light is amber and the hard drive light is green, the diag. lights in the rear are either off or...
The power supply may be going out. Go to the Dell website, select support, enter your service tag number and find your symptom to determine the problem. The lights in the back will help you isolate the issue by cross referencing it to the lights that are lit and not lit.
Nov 02, 2010 | Dell Dimension 2400 PC Desktop
What kind is motherbourd
The Dell Dimension 2400 motherboard is proprietary to the Dell Mitac Chassis. It should work in any Dell 2300/2350/2400/4600/4700 case. The main item is the Dell specific power/control panel connection. If you move the board take the control panel with it.
(Personally, it isn't worth the effort)
Jul 05, 2010 | Dell Dimension 2400 PC Desktop
My son cannot get to his new email address
I am sorry but without more information I cant help you or him.
I need to know what kind of email address he has. Is it one of the cheapo free ones from google (gmail) yahoo or hotmail? Or is it a good old smtp email address that you would access from outlook express or windows email program?
windows xp and older used outlook express as a default email program. Vista and newer have a windows mail program somewhat inferior to the old outlook express.
Gmail, yahoo, and hotmail are all browser based and as long as you know your signin and password you can access it from any computer.
Apr 12, 2010 | Dell Dimension 2400 PC Desktop
What cable for Gateway FPD monitor to Dell Dimension 2400 compute
You can either use a dvi or vga cable, for more info go to http://service.gateway.com/s/Manuals/Monitors/8511253.pdf
Mar 03, 2010 | Computers & Internet
Most likely from tripping over cables over
Hi George
I would simply recommend having the board replaced or upgraded as its not wise to have soldered connections flying around. The only problem is that the system being that old is not going to be an easy one to source a motherboard for.
Sorry i couldnt be any more help.
Taz
Oct 24, 2009 | Dell Dimension 2400 PC Desktop
My motherboard wont fit into any case ><
all motherboards have a size known as "form factor"
*********** baord is Micro ATX,
youll have to buy a case that can fit that motherboard in or buy another motherboard that will fit in your case, youll have to find out your dell model number to find the form factor, easiest way would be search your old motherboard number
Jun 04, 2009 | Intel D845GVSR Motherboard
I need a motherboard manual
Motherboard manual for this model is not available.
However you can download the full user manual here.
You find main info on motherboard and on diagnostic code in the manual.
Feb 24, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400
The front side bus speed of the processor is the limiting factor of your RAM speed.
The Processor has a 400 Mhz FSB, hnece your RAM runs at 266.
For RAM to run at 333 (PC 2700), you'll need a 533 FSB Processor.
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
EliteGroup K7S5A Pro Motherboard Logo
10,573 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
