Question about Kitchen Ranges
I have a brand new electric Jenn Air Convertible Cooktop ModeL C101-C , has two coil burners and a baraque grill. i need the electric diagram to wire it in to my electrical panel. which wires are what, i know its is 220 volt hook up i just need to know what wire are which by color. please help thank you. i have had this for ten year never open the box and just finish my new kitchen
    Genius:
  • 1,073 Answers
Black and red hook to the 240 volts white is nutral and green is frame ground if you do not have a green wire then bare copper to bare copper or green to bare copper national electrial code
Posted on Apr 11, 2008
New knobs & pans
A good place to start is the local agent or manufacturer,
Apr 09, 2014 | Jenn-Air Removable Cooktop Grill - Part...
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Use and Care Manual for a 89353 Tri- Convertible Grill Range
You can get parts for you cooktop on the link below. just click on the area that needs the part.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=89353-8&productCategoryId=0121060&brandId=1266&searchedModel=
As for the manual you might beable to get one from your local sears part department.
Good Luck
Jul 01, 2010 | Jenn-Air JED8230 Electric Cooktop
I have a Jenn-air, C206-C model grill-range cooktop. Three of the 4 burners have stopped working. Any solutions?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jun 04, 2010 | Jenn-Air JED8230 Electric Cooktop
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Three of my Jenn Air burners (electric) only work on High - OLD
Hello
Welcome to Fixya
My name is Huum,
you can find the schematics, diagrams and parts here at this site . just enter the complete model number that is written on the stove sticker and access the info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
Please remember to leave a rating before you leave
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Both burners turn on when only one is needed
I just had the same problem- when I replaced the whole cartridge.
I repalced the infinite switch- do the one that gets the hottest- or do both.
It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
good luck
Jun 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Kitchen Ranges Logo
106 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
