Question about Sony Handycam CCD-TRV37 Camcorder
Tape cassette door won't open
I tried removing small and large batteries, tried Sony's website, error code 32:11, removed power cord and battery, put switch in camera position for 15 seconds, reinstalled cord and battery, no help, tried sharply hitting the door a few times which worked for some people, but not me, took the casing off the door and tried to find the release mechanism and couldn't, it coses to much to take to a repair shop and I can't afford a new one. is there anything else I could try, including unjamming the gears or taking the camera apart to fix it. does anyone have instructions as how to do that or how to troubleshoot the problem? Bob
    Sergeant:
    Champion:
  • 319 Answers
Try removing all batteries from unit for 24 hours, then try to power it up in OFF position. If you still get error code, unit has mechanism or power problems. Striking the unit will not make it work either
Posted on Aug 01, 2008
How to fix sony camcorder with tape deck that won't close. camcorder squeals and ejects tape.
bit late...but. STOP ASAP! by removing the battery, after removing battery, wait 20 seconds, re-fit battery & CLOSE the cassette door.
then wait 10 seconds, slap the closed door twice quite firmly. then open, if it opens, discard that cassette tape, clean the players head using cleaning tape.
use new cassette tape.
Jun 30, 2015 | Sony Video Cameras
Tape is stuck
First take out the battery. Then start unscrewing the outside panels to take it apart. Basically any screw you find, take off. The easiest way not to loose them is by sticking them into the side of a box. After you get the camera panels off, you should be able to carefully get inside and dislodge anything that may be in the way. Once you are able to dislodge the cord or whatever is causing this problem. Try inserting the battery and ejecting the tape. Let me know if you are having any trouble with this or have any other questions and I would be glad to help.
Good luck
May 20, 2008 | Sony Hi8 Hi-8 Tape
Error code
I believe this means that there is condensation in the tape mechanism.
Apr 06, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Sony TRV530 has cassette holder stuck half way out
Thats an interruption of the ejection process, either you push it, you were on low battery, the energy was interrupted or you leave the camera in a car and th heat/cold affects it. Try to cheat/reset the camera system: Remove the clock cell, remove the battery or ac/cord at the same time you push the eject button once. Wait for an hour. Place the clock battery. Connect the AC/Charger cord or the battery (it MUST be completely charged). The camera will reset, check out and complete the ejection.
Jun 24, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Mar 07, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
Cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
Dec 10, 2008 | Sony Handycam CCD-TRV107E Camcorder
ERROR MESSAGE C 31:23
The error code is part of a self diagnosis feature of your cam. This particular code refers to something being wrong which you can fix yourself. The steps you should take, involve removing tape, and reinserting. removing power adapter plug and reinserting, remove battery pack and reinsert...
power down before each step, and power up again to check working status. The result of these checks should allow you to narrow down the problem.
You may have to look at trying a new battery, or replacing the cassette, or replacing power cord, or you just had not properly hooked something up, or the cassette wasn't properly seated.
These codes and their meaning can be found in your user guide, or manual. Good Luck!
Nov 11, 2008 | Sony Handycam CCD-TRV108 Camcorder
Cassette jam
I had this problem, and here is how it was resolved.
My cassette would not pop out when I opened the door with the camera turned on. When I turned off the camera and opened the door, it slid out much further, but still failed to pop open so that I could remove the tape. Then it slid back in.
Remove the battery, and have the camera off, but make sure the power cord is connected. Open the door until the tape slides out further than at other times. (Note: It intermittently slides out further when the camera is off. Sometimes it will not slide out any further than when it is on.) When the tape is slid out as far as it will go, quickly remove the power cord. The tape will stay in the slid-out position. Now, at the bottom side of the tape door there is a curved channel for a small pin to slide in. This channel has a 90% curve at the bottom of the channel to catch the pin, which holds the door closed. Push that pin back a little (toward the lense) to get it to go around that 90% curve, and the door will pop open so you can remove your tape. The ribbon of your tape will be jammed in the camera a little, so you will have to be careful and move the ribbon around a little until you can get it out freely.
This worked for me twice. I did not try putting a tape in again.
I hope this helps.
Apr 10, 2006 | Canon ZR10 Mini DV Digital Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Sony Handycam CCD-TRV37 Camcorder Logo
174 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
