My touch pad is loose in place (pal top fell down) is there any drawing to show how to open and dis assemble this laptop and change the touch pad. Next what do i need to change the operating system from vista to ep in this laptop
    Genius:
  • 1,142 Answers
Plz specify the amke and model of ur laptop so that i can provide u the specific disassembly instructions
Posted on Apr 11, 2008
I have an acer laptop and the cursor jumps all over when im typing and randomly selects sections im not touching the mouse pad at all
80 % IS MOUS DRIVER , 10% MOUSE PAD ,dis able the , the touch pad from front of the top case by switch , and connect the external mouse and check the system.
Jan 09, 2013 | Acer Aspire 7110-2069 Notebook
I have the GE GSS25QSTASS unit and all of a sudden the ice dispenser just starts up without pushing the lever. When you open the freezer door it stops, but once the door is shut, it automatically starts...
In most case I have run into the=> WR55X10859 Dispenser Interface is the problem because the touch pad contacts have failed and are now touching each other behind the surface of the touch pad. Like a key on your computer keyboard being stuck on. I can assist you from here if you like in dis assembly and diagnostics. Here is a link to a list of photos that help in disassembly=> Here You will need to scroll down to near bottom to see the GE Dispenser dis assembly instructions. Please rate this solution if helpful and if you have any questions please ask, Thanks, Sea Breeze
Apr 21, 2011 | GE GSS25QSTSS Stainless Steel
When I open my lap top, My screen goes hay wire and I have to open and close the screen until I find a position that it stops.
The problem is most likely the video cable from the motherboard to the LCD screen has become loose and needs to be reseated back in place. It will need somebody to do a partial dis-assembly to fix the issue or a computer technician.
Jan 23, 2011 | Toshiba Satellite PSAG0U-02D00M Notebook
Problem scrolling pages using touch pad on HP laptop
Hi Clay, I want you to pay attention next time it happens. Reply to this thread by telling me if it strictly happen during or after watching online videos. I also need a bit more specs on your rig. Model number and Operating system. I'll respond accordingly. Best way to find a solution is by narrowing down the problem.
Mar 08, 2010 | HP Computers & Internet
I need to replace dc jack on my Acer extensa 4420 laptop, but the bottom cover won't pry off (I removed all the visible screws). Am I missing a step? Most computer covers pop right out once you removed the...
if it has 'rubber' non-slip pads, try prying them off- may have screws under them- hope you're really good with a soldering iron!! may just need to re-solder loose connection! good hands, good eyes, good iron!! use 'organic-core' solder!!
good luck! may have screws under battery slot, ram cover, hd cover! can be a royal pain! may check their web-site for 'exploded' maintainance' diagrams showing how to dis-assemble laptop! don't forget, they're small and light for a reason, and not as forgiving as desk-tops!! whatever you do-remove power supply cord & battery, before you continuing to dis-assemble it! no- i'm not considering you stupid!!
you obviously have diagnosed the problem, and are trying to access the the problem area! i've seen several laptops with the same 'weakness'- it's like- 'DUH'- couldn,t you find a better place to save a few cents?? a major stress point! bet it keeps the 'official' repair centers in the 'bucks'!
ah, well! enough grousing- again- good luck!
Oct 23, 2009 | Computers & Internet
Error code f-21 how can I tell if the pump is bad
according to the whirlpool website the f21 is a communication erroe, nothin to do with pump. if you remove the top panel from washer (3)screws from across the rear of unit, youll find the main control board just under there. i would look for loose wiring connectiond at tha point.
f21=
This error occurs if the touch-pad/LED assembly is not
able to transmit/receive data to/from the central control
unit (CCU).
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting
different cycles and changing the modifiers and
options available to confirm the touch-pad/LED is
responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How do I remove and replace the Lcd on a Compaq Presario 2100?
disassemble the laptop screen by removing the screws hidden under the rubber pads. dis assemble the case. Simply unplug the old lcd scr and swap. Be carefull not to touch the back of the new lcd. re assemble
Jul 15, 2008 | Compaq Computers & Internet
Whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Jun 28, 2008 | Whirlpool GHW9400 Duet Washer
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
