FixYa.com
Tags:
Jenn-Air JGW8130A Electric Single Oven
No power - Jenn-Air JGW8130DDB (by 2 users)
posted by turkn8or on Apr 11, 2008
This is a 120 volt gas oven (Jenn-Air JGW8130DDB). The drop-down did not let me select the exact model of my oven so I chose the closest model. I'll open it up and make sure the connections are secure. Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 25, 2008
That's a no-brainer. The first thing anyone would check is the outlet (works fine).
Solution #1
Not Rated (0)
TJBENGR
Rank:Guru Guru
Rating: 85%, 51 votes
Also check for power at the wall plug. Fuse?
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Ovens problems?
Ovens
e1 f2 error
get e1 f2 message on startup Answer This...
Ovens
oven control pad
The display shows S Ab Answer This...
Ovens
ZANUSSI FCF/E101
Please could you halp me find a... Answer This...
venting of wall oven
After a while the heat coming... Answer This...
Send message DOOR
I Have a problem display... Answer This...
Repair Service
Find Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
