HP DeskJet F380 All-In-One Printer Logo
Posted on Jun 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The printer fails to print - HP DeskJet F380 All-In-One Printer
Anonymous
Level 2:
  • Expert 241 Answers
  • Posted on Jun 09, 2010
Anonymous
Expert
Level 2:
Answers
241
Questions
Helped
159391
Points
801
Have you checked your cables and made sure the printer is turned on? After making sure you have your cables correctly installed and have turned your printer on, try printing a test page from the printer properties.
If this fails check your cartridges to see whether they are installed correctly and whether or not they have dried out if you haven't used the printer in more than a few weeks this can happen. If this fails post more information eg: any error messages or if the printer seems to not be powering up, grinding noises etc.
Print head isnt moving when turned on.
Which printer model you have used? If you have Air blockages in nozzles, dried ink in the print head, insufficient ink in cartridge can be caused of print head failed or not moving issue. You can easily have fixed the printer printhead failed issue with simple methods.
Reset your Printer Print head
Reset your printer
Clean printer ink cartridge
Read more steps to fix the printer printhead failed or not moving issue.
How to set print alignment in hp officejet K7100
During cartridge alignment, the error message 'Print cartridge alignment failed' displays on the printer control panel....
More Info visit this links...
Print cartridge alignment failed Error Message Displays on the All in...
Alignment Page Does Not Print
Thanks,
HP Printer Support
2helpful
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
3helpful
Resume not working
Sounds like head failed replace it see below
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
EPSON POS PRINTER does not print receipt
Try to clear your printer's queues up messages of all print commands that failed to print. See, what happens it when you send a document to printer, if it fails to print, and you send another, it queues up behind the first that failed to print. So instead of printing the second document it prints what you are seing, special characters etc.
Solution:
Go to start/priners and faxes and right click on your printer and select open. You will all the documents for print so far queued up. select and delete them. Restart your system and the printing should be Ok.
2answers
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
k24674
Grand Canyon Tech
Grand Canyon Tech
