Question about Philips Magnavox 51MP392H Rear Projection Television
Intermitant Convergence Problem
"Bowing" and distorted picture. Looks like a really bad 3-d picture. Sometimes it lasts longer but for now it eventually goes away either after the set has been on for a while or been turned off and on a few times. When it is in this "funky" mode, I can not adjust the manual convergence. When it clears, the convergence appears to be perfect.
I've seen several posts about the ICs needing to be re-soldered or the power supply needing to be replaced. I am not an electronics wiz (nor do I have access to any solder equipment). I paid less than $1000 five years ago for the 51" Magnavox...just wondering if it's better off to replace rather than spending what I imagine will be several hundred $$.
  • 2 more comments
  • qgijoe69 Aug 08, 2008
    I have the same problem and if I cut it off and on after it has warmed up for a while it will fix itself. Other times it will come on normally
  • indy80 Aug 10, 2008
    have bad picture look's like duble image
  • a1home Aug 18, 2008
    looks like a 3d picture.green & red are out of alignment. Picture is crooked . Just started a few days ago. Stays this way. no change when it's turned on & off. Should I replace it or can it be fixed.
  • ford8832 Aug 25, 2008
    Same problem red and green are 3D. I need to watch it with those funny 3D glasses. KIDDING. Tried turning T.V on and off but no help. This just started a few days ago. Also tried adjusting the convergence no help. When I fix the problem I will post the repair. I just have to narrow the cause which can only be a few items. I hope.
  • Philips Master
  • 3,459 Answers
Shrinking and expanding  video or no audio/video is fairly common problem. Goto www.magnavoxhelp.com to see if they have a repair kit for your model.
Posted on Aug 06, 2008
  • 121 Answers
If you cant do the repairs yourself you can go to the link i give you leave an e-mail they repair the convergence circuits and guarentee them for 6 mos
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
My option will be to replace it. or spend couple of 100$ and get it fixed
Aug 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Problem with Sony KP46WT500: Each line on the
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | Sony KP-46WT500 46" Rear Projection...
Bowing convergence lines , projection tv
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Feb 04, 2010 | Mitsubishi VS-80803 TV
Bowing of picture at top and bottom towards center.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
SPEED BUMP OR BOWING
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking. Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com for a kits.  Just make sure you replace both of the convergence chips and all of the convergence resistors.
Aug 25, 2008 | Philips 60PP9202 60" Rear Projection...
I am thoroughly confused now
yes the convergence iCs will give you a severe picture distortion bowing in either from the top bottom or sides.as well as the 3-D look
Mar 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Bowing at bottom
convergence ic bad, should also replace bad caps in DM
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
· http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
