Question about Bose Lifestyle 38 System
Switching form PAL to NTSC
By accident, I switched my display mode on my system from NTSC to PAL. Now, when I try to switch it back to NTSC by opening up the system menu, there is a blue screen, and a message box pops up, saying: "Not supported mode".
Thank You
  • LRandCori May 31, 2008
    I did exactly the same thing while messing around with the remote. My stupid error, yes, but now, HOW DO I GET IT BACK!!??!
  • bwed Oct 02, 2008
    I have the same issue. I tried accessing the system menu from memory, but obviously I was unsuccessful. How did you switch the system to NTSC?
    Thanks
    John
Did you tried to switch back to factory settings? thanks
Posted on Oct 08, 2008
I cannot play NTSC DVD's on my Bose system
thats because your region is for PAL-SECAM. Your unit cannot recognize this format unless it has been programmed to automatically play NTSC & PAL-SECAM.. Browse the menu and try switching to NTSC format. hope this helps ;-)
Feb 04, 2011 | Bose Lifestyle 38 DVD Home Entertainment...
Colors are off
Hi!
maybe your PAL NTSC SYSTEM mode is in accidentally switch to PAL or NTSC try to re switch the PAL NTSC SYSTEM mode.
Nov 02, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
How do you change the DVD player mode from PAL to NTSC ?
I just found the way to change the setting from PAL to NTSC.
While the unit is turned off , press the EZ View button on the remote control. Press alternatively the select between the PAL or NTSC setting on the unit display. That's it.
Mar 17, 2009 | Audio Players & Recorders
Switching between Pal & ntcs
This units display color system is set for NTSC. As far as I can tell you cant change this setting. You can refer to the display information in the manual. Page 111 of 128 at: http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF
Oct 06, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Oritron dvd 3119 player
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
Jul 29, 2008 | Oritron NPD3117 DVD Player
Can't get colour when playing back videos and dvd's
Is the picture still or it scrolls? You may be playing NTSC tapes and DVDs on a PAL TV or vice versa. If your TV supports multiple systems, try switching from one system to another (like NTSC from PAL).
Dec 14, 2007 | Sharp DV-NC80 DVD Player/VCR
PAL mode ?
PAL/NTSC is automatic. if you insert a PAL DVD output is PAL ( most probably PAL-B. Some other brands allow manual PAL/NTSC switching, but at this machine this is automaticaly done. Please verify your TV set allows PAL programs
Oct 27, 2007 | Sony DVP-NS50P DVD Player
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
Sony Mobile DVD MV-7101 Display is Black and White
Try pressing the arrow up on your monitor while it is on the PAL mode. This is what I just tried on my systema and it switched from PAL to NTSC.
Jan 07, 2007 | Sony MV-7101DS Car DVD Player
Bose Lifestyle 38 System Logo
283 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
