Help i did exactly what i did following ur codes but am not sure if i am set it up correct. the ligts does blinks and everything but still wont change channels or turn on or off?
  • 3,037 Answers
Ok, you can also try the following without a code, I have a question for you since those codes didn't work, the manual that I gave you, the picture of the remote is the same, similar, or totally different? If you can give me the model of the remote (not the brand name) I may be able to find something even more specific or it might have different codes but the below can be done without a code and since you say that the remote seems to be programming, just not accepting the codes, then I think the following should work, it just may take some time. That manual that I sent you, you should probably print out and the directions below are from it. Thank you
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold Code Search button until the red
indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR,
etc.).
The red indicator blinks, then stays lit.
4. Press the Channel Up button repeatedly (up to 300
times) until the device to be controlled changes
channel. The red indicator blinks, then stays lit. If
you accidentally overshoot the code required, press
the Channel Down button to backtrack through the
library until the device changes channel. Pressing
Channel Up changes direction to forward again.
Press and release the Mute button to install the
code.
The above assumes that you want to store VCR codes
under the VCR button, Cable codes under CBL, etc. If
you want to store a VCR code under CBL, etc., first
follow the procedure on page 10 and try ANY CBL code
from the code tables, e.g. press CBL in step 2, page 10,
and then enter ANY VCR code. Then follow the steps
above.
Note: If the device does not have a Channel Up button,
use Play (VCR only) or Power instead. Code Search
starts from the currently stored three digit number
under that mode e.g. if the mode has 100 codes and the
currently stored code is 050 then the Code Search starts
from 051 continuing to 100 before looping back to 000
and finishing at 050. This simplifies the process if you
find that several preprogrammed codes operate your
device by allowing you to bypass codes already tried.
Posted on Apr 11, 2008
Panasonic TV PC T46G25, Year 2010....wont turn on.... I had 10 blink code so i changed the power supply board and Now i have 7 blink code. Kindly please help????? Urgent
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 22, 2017 | Panasonic Televison & Video
I had hitachi plasma tv p42a01a got green light blinking 3 times . How to solve it . I really need ur help . Tq .
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 28, 2016 | Hitachi Televison & Video
RED LIGT KEEP BLINKING ON TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 18, 2015 | Televison & Video
TV WONT COME ON RED LIGHT JUST BLINKS
Jun 05, 2015 | Televison & Video
I have changed the lamp, and is fitted correctly..i have plugged in the tv and the standby light just flashes green , pressed the stanby button on remote , still nothing..
Have you reset the lamp time; before replacing the lamp? If not, the set won't start. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Procedure for lamp replacing to various brand projection TVs are given.
May 09, 2015 | Sony Televison & Video
Bush 26" free view HD tv has power blinking blue but wont turn on
Dec 06, 2014 | Bush Televison & Video
Grenn ligt blinking will not work
Sep 12, 2014 | Element ELC-HS321 32 in. LCD TV
Pioneer plasma problems
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 10, 2014 | Televison & Video
When i connect all cable my Linsys wrt54 g is not workin and my indternet conction.
First, make sure that all your cables are plugged in correctly. If everything is connected correctly, the lights on the front should start blinking. Once they start blinking, you can follow the guide here:http://www.columbia.edu/acis/networks/aptnet/linksys/index.html This guide will help with setting up the router, as well as making it secure. Hope this helps!
Mar 28, 2011 | Linksys Wireless-G WRT54G Router
TURN SIGNAL LIGT WONT BLINK ,JUST STAYS ON
dont replace the switch make sure you have the correct bulb installed correctly first. might save you another headache i take it the other blinkers work than you have a good relay good luck
Apr 14, 2009 | 1998 Volvo V70
Televison & Video Logo
Top Televison & Video Experts
