Question about AMD Motherboard, nForce4 SLI, S939, Athlon 64/64FX/64X2, Max. 4GB DDR, 8 SATA, 2 IDE, GBE, 1394a (NF4SK8AA8EKRS)
Internal i went to change my tower little did i know the towers were built backwerds, when i put it all back together it worked fine BUT i have no sound now
  • dirty shmut Apr 11, 2008
    i think its the wire not shur
  • 101 Answers
The motherboard mounting stand-off (metallic) might be shorting the connections on the mobo check that out.
Posted on May 01, 2008
My tower was working fine till i moved it when booting up it now reads 'no signal detected'
Looks like when you moved the pc you have made the graphics card just come out a little if you open the case up pull the card out re seat it should work depending on what card and what board you have you may have another slot you can put it in.
or there will be jumper refresh on the board to flash the bios to clear the internal memory you may have to do that but that should fix your issue.
Regards
Simon
Netdaddy.co.uk PC Repair Port Talbot
Sep 21, 2012 | Antec Performance Sl300s 300 Watts...
Got an acer aspire ax3812 tower is on but screen stays blank got any ideas
Change the internal Ram sticks. This can cause a "Hold" in the BIOS boot process, thereby stopping the machine from going to the Operating System. Hope this helps.
Jan 29, 2012 | Acer Aspire Computers & Internet
Gold's gym XR10.9 power tower
I had the same problem regarding the assembly manual for the gold's gym power tower. I went to Iconservice.com. What I figured out was if only put "golds gym" and left off model number and the other information. All of the gold's gym product line manuals would pop up. Scrolling down I notice a product with the same model number that is on the box (except it was labeled a bench instead of "power tower") I clicked on it and sure enough it was the manual for the power tower.
Jan 23, 2012 | Exercise & Fitness
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My hp tower has a built in speaker how do I turn it off. I just want to hear sound from my speaks not the built in speaker
    You have 2 options.
    The easy one is: double click on the audio device at the task manager in order to open the audio mixer, try to locate the (internal) speaker slider and slide it all the way down. If the speaker slider is not viewable choose option and try to locate it at the new window in order to enable it and come viewable and then change it's volume. If the above method prove not to work you have to follow the hard way.
    Open up the case. Locate near the front side of the tower the built in speaker. It has one pair of cables that are connected with a small plastic connector at the motherboard. Unplug the connector; maybe there is a clip in order to unlock the connector, use a small screwdriver with care not do make any damage at the motherboard. Close the tower and enjoy the sound from your speakers without the interference of the internal speaker.
    In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
    If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
    Thanks and regards
    Please kindly rate this solution
    Stelios
    direct fixya link: http://www.fixya.com/users/technical114
    Sep 04, 2010 | HP Compaq Business Desktop d330 Slim Tower
    Grinding noise in tower
    Grinding noise in tower If everything on your computer is working fine then it is probaly a fan put your ear in the back of your tower near the power cord and see if you can hear the grinding noise better if you can then your power supply's fan is going out if not its probally one of the inside fans in your tower open up your tower and see if you can find which fan it is if you dont want to do this you should probaly get a tech to look at it it's a pretty cheap fix and it can save your computer from heat dammage
    Nov 07, 2009 | Computers & Internet
    RCA HD52W59 HDTV arcing internal high voltage tower help
    http://www.riddledtv.com/repair/RCA.html
    http://serviceman.site88.net/index_files/Projection.htm
    try these sites see if they help u
    need to know chassi
    Oct 03, 2008 | RCA HD52W59 HDTV Projection Television
    Desktop comp. compaq
    If it is soldered, that's a hassle. You can make sure the wire is stripped and use duct or electrical tape to make contact with the "+" side of the battery.
    Jul 20, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
    Spray tower came off the filter module
    Are you talking about the tower attached to the lower rack?
    Aug 18, 2007 | Whirlpool 24 in. DU900PCD Built-in...
    AMD Motherboard, nForce4 SLI, S939, Athlon 64/64FX/64X2, Max. 4GB DDR, 8 SATA, 2 IDE, GBE, 1394a (NF4SK8AA8EKRS) Logo
    Top AMD Computers & Internet Experts
    Alun Cox
    Robert Monigold
    Robert Monigold
    Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
