Need the manual for magnavox for codes listed
I try byt can't do it not sure how u do it like press tv then set then codes number then enter and try?
  • jubutt Apr 11, 2008
    anyone have maual remote codes listed for magnavox? so i can set it up for my sylvana tv help me thanks
  • 3,037 Answers
The manual link that I posted had the directions in it but here they are for your convenience
Direct Code Entry
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV, VCR,
etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
Posted on Apr 11, 2008
  • Benjamin Patri
    Benjamin Patri Apr 16, 2008
    do you still need the codes?
Sony remote rmtb119a tv code for magnavox
I just keep trying different codes for for my Magnavox TV. Since they started at 01 for Sony TV's I just keep working up from there. For me it ended up being 22. Here are the complete instructions from sony's site:
Follow these steps to program the remote control to operate a television.
  1. Turn on the TV.
  2. On the remote control, press and hold the TV I/O button.
  3. While holding the TV I/O button, enter the manufacturer's code using the number buttons. 22
  4. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  5. Release the TV I/O button.
  6. Point the remote control at the component.
  7. Press the TV I/O button to verify operation.
Feb 05, 2013 | Sony RMTD187A Remote Control
I have a Magnavox 15MF605T/17. I bought an RCA universal remote, part number RCU403R and cannot get it to work.
Check these codes.
1454, 0054, 0030, 0096, 1963
Manually turn on the TV.
Find the three-digit code for
your TV in the code list below.
2. Press and hold the CODE
SEARCH button until the
INDICATOR LIGHT lights, then
release the CODE SEARCH
button.
3. Press and release the TV button
(The INDICATOR LIGHT will
blink then remain lit).
4. Enter the code using the
Number Buttons. After your
code is entered, the INDICATOR
LIGHT will turn off.
5. Aim the remote at your TV and
press the ON•OFF button. Your
TV should turn off.
Note: If your TV does not
respond, try all the codes for
your brand. If the codes do not
work, or your brand is not
listed, try the Code Search
method on page 10.
6. With your TV on, press CH+. If
the TV responds, no further
programming is required
Jul 10, 2012 | Televison & Video
Need code to an rca universl remote to control a magnavox tv
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Magnavox TV Codes: 006, 007, 010, 013, 016
Sep 21, 2011 | RCA Computers & Internet
I got a Magnavox tv model number 27ms343s from a friend,but it didnt have a remote.The tv is locked and wont turn on by the power button,how do i find a code to set it up with my dish network remote?
We would be happy to help you with getting your DISH Networkremote to control your TV. Pressand hold the TV button located on the top of your remote until all mode buttonback lights come on, then release. Use the number buttons to enter thecodes for your Magnavox television; here some of the codes we currently have: 560, 829, 566, 761, 891, 828, 656, and 770.Press the pound (#) button. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the TV. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this help and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 10, 2011 | Philips Magnavox 27MS343S 27" TV
Need instructions to set code for tv
  • 1 Download or view the user's manual from the Magnavox website (see Resources). You will need the list of codes included in the manual. The website will direct you to the closest remote control manual available similar to the REM 350 Universal Remote. This manual is compatible with the REM 350 Universal Remote.
  • 2
    Press and hold the "Code Search" button until the red indicator light stays on. Release the "Code Search" button.
  • 3
    Press and release the "Mode" button for the product you wish to program (TV, VCR, DVD or satellite). The red indicator light will blink, then stay lit.
  • 4
    Enter the four-digit code from the code tables listed in the user's manual. You can also search for the code online at the Philips Universal Code Finder page (see Resources). You might have to try several or all codes listed in the manual until you find the correct one. After a valid code entry, the red indicator will turn off. With an invalid code, the red indicator flashes.
  • 5
    Press the "Channel Up" button with your device on (TV, DVD, VCR, or satellite). If the device responds, you have completed the programming. Once are certain you have found the valid code, make a note of it somewhere so you will not have to search for the code again.
  • Jan 14, 2011 | Philips Magnavox REM-350 Remote Control
    Dishnetwork remote , what do i push before entering codes for magnavox
    We would be happy to help you with getting your DISH Networkremote to control your Magnavox TV. Press and hold the TV button located on the top ofyour remote until all mode button back lights come on, then release. Usethe number buttons to enter the codes for your Magnavox TV. Press the pound (#)button to save the code in the remote. To check that the code works try several different functions on theremote to make sure it will properly operate the TV. Remember that some codesmay not be compatible with your equipment. If this is the case, try the othercodes listed for that device until you find one that is compatible with yourequipment.
    We hope this helps and thank you for being a valued DISH Network customer!
    Phillip Chang
    Oct 20, 2010 | One For All URC-3021 Remote Control
    Need code to reprogram oneforall remote for
    To control a Magnavox TV with a One for All URC-3021, follow these steps:
    1) Turn on your TV.
    2) On the remote, press the TV key once.
    3) Press and hold SET until the LED blinks twice, then release SET.
    4) Enter the first four-digit code from the following list:
    0054, 0706, 0030, 1454, 1254
    The LED will blink twice.
    If it does not blink twice, go back to step 2 and try the same code again.
    5) Aim the remote at the TV and press POWER.
    The device should turn off.
    If it does not turn off, repeat steps 2 through 5 with the next code in the list.
    I hope that helps.
    Nov 27, 2009 | One For All URC-3021 Remote Control
    Code lists
    Try these codes: Magnavox 0503, 0539, 0675
    Jun 15, 2009 | Radio Shack (15-2147) Remote Control
    Somone set the smart lock on tv dont know the code
    This information was found on the Magnavox customer support website. http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=TV_CONVENTIONAL_CA&sct=TV_LARGE_25_29_SU&grp=TV_GR&session=20090602222010_68.190.209.25&ctn=27MS343S&mid=Link_UserManuals&hlt=Link_UserManuals It is located in the pdf copy of the owners manual on page 23. If this information does not help you solve your problem you can call Magnavox customer support at this telephone number 1-800-705-200. Give them the model number of you television and the problem you are having the smart lock feature. They will be able to help you solve the problem. I hope this information help you with you problem 1 Press MENU to show the on-screen
    menu.
    2 Press VOL+ or VOL- to highlight SET.
    3 Press CH+ or CH- to highlight
    PARENTAL CONTROL.
    4 Press VOL+ or VOL- to display the
    SECRET CODE screen.
    5 Press VOL+ (on the remote) and the
    CH+ button on the front of the TV
    at the same time.
    6 Press the Number buttons to
    enter a four-digit code. The code will
    appear on the screen as you enter it.
    The code “0000” is the default of the
    TV. If you have not set up a code previously,
    then “0000” is the code.You cannot
    use “0000” after you set your own
    code (unless you reset the code to
    “0000”).
    7 Press MENU to save the code.
    8 The Parental Control menu will appear
    next. Press TV/AV/EXIT to remove
    the menu, or continue from this point
    to change your Parental Control settings
    Apr 05, 2009 | Philips Magnavox 27MS343S 27" TV
    Need to program a ge universal remote control to operate a Magnavox Total Control System TV
    here is the 3 digit codes ive found to try 586, 651, 720, 666, 731, 800
    MAGNAVOX ............ 0062 0004 0009 for digit codes
    ........................... 0456 0183 0226 0288
    ........................... 0008 0068 0075 0141
    Manually turn on the device (TV, VCR, DVD, etc.) you wish to
    program.
    2. Press and hold the CODE SEARCH/SETUP button on the remote
    until the INDICATOR LIGHT lights, then release.
    3. Press and release the button for the device you are programming
    (TV, VCR, DVD, etc.). For AUX, press AUX then the device button
    you are assigning to AUX. The INDICATOR LIGHT will blink then
    remain lit.
    4. Enter the three or four digit code for your device using the number
    buttons in the GE Universal Remote. After your code is entered the
    INDICATOR LIGHT will turn off.
    5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
    POWER button. Your device should turn off.
    Note: If your device does not respond to the first code listed,
    repeat steps with the next code. If none of the codes listed for your
    device work for your device or your brand is not listed,
    try the Code Search method described below.
    USING CODE SEARCH FUNCTION
    If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
    for your brand or if your brand is not listed, try searching for your codes by
    following the steps below.
    1. Turn on the device you wish to program.
    2. Press and hold CODE SEARCH/SETUP until the INDICATOR
    3. Press and release the device button for the device you are
    programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
    blink once then remain lit. For AUX, press AUX then the device
    Jun 21, 2008 | Televison & Video
    Televison & Video Logo
    35 people viewed this question
    Top Televison & Video Experts
