Question about RCA P60921 60" Rear Projection Television
Clicking sound! My tv turns on with the power button light is red and a clicking sound coming from the back of the tv, no picture no light on screen. Please help, no picture, no sound, click goes away only when unplug the TV
  • RCA Master
  • 19,396 Answers
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 15, 2009
Flat screen tv
Open internal fuse or power supply failure
Aug 30, 2016 | Televison & Video
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
BUSH 42" plasma no picture or sound?
You have a power supply problem, replace the Module.
What you ear is a click relay No juice to activate the relay
Some cups may be dried.
Nov 01, 2012 | Bush Furniture Bush My Space Rhea 42 in....
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
May 16, 2009 | Televison & Video
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
RCA P60921 60" Rear Projection Television Logo
480 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
