Playback speed when playing a prerecorded tape, the voices and speed are too fast
  • buzzard551 Sep 28, 2008
    playback on my teac w-45 sterio double cassette deck is fast, how do i slow it down?
    Sergeant:
    Champion:
  • 319 Answers
Deck probably has a failing drive motor. Take in for service
Posted on Apr 23, 2008
Tape is playing back in fast forward only
It is possible the tape loaded on the wrong side of the drive. If you romove the tape, look for slack and tighten up, try it again or another tape. Otherwise it is likely that a spring for the pressure roller is off or broken. This is not easially repairable.
Oct 19, 2011 | Sony M-670V Handheld Cassette Voice...
HOW DO I GET IT TO PLAYBACK AT NORMAL SPEED
go into the menu and set the playback speed to normal,not fast or slow,if its a tape machine,set the speed using the small switch on the side that says 2.4/1.2
Mar 23, 2010 | Olympus Audio Players & Recorders
My Olympus Pearlcorder J300 plays the tape back too fast
Hello check the switch for VOX needs to be in the middle position make sure is not on F.Play
If the speed doesn’t change is your main motor
Apr 03, 2009 | Olympus Pearlcorder J300 Handheld Cassette...
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Jan 25, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
VHS system malfunction
VCR's automatically detect what speed the present tape was recorded at. It only gives you a choice of speeds when doing the recording. If you are saying that it won't playback a tape recorded in one of the slow speeds, it is most likely because VCR's with more than two heads use different combinations of them in different speeds and the ones used for slow speeds are maybe needing cleaning. If this is the case, the vcr will seem to be playing OK, but the video playback will be bad.
Dec 25, 2007 | Goldstar GVR-DD1 VHS VCR
Playback is speeded up on taped recorded at SLP Symphonic VCR SE 226D
buy a new damn vcr o ya We r in the 21st century we now use dvd's go get ya self a dvd player abd you wont have that problem.
Dec 10, 2007 | Televison & Video
Tape decks playig too fast
Hi I can probably tell you what is wrong, but there is usually not much you can do except take it to a shop and have the motor replaced. I most cases there is a hole in the back of the cassette capstan drive motor, or on a small circuit board close to the motor where the speed is adjusted at the factory. You could possibly adjust the speed by ear until it sounded right playing a factory recorded tape with a song you know well, but I recommend these adjustments be left to a tech with a frequency counter. Also, these adjustments normally never need to be touched unless replacing a motor, so it is likely something internal has gone wrong with the motor, and it should be replaced under most circumstances. Hope this helps, Good Luck.
Sep 27, 2007 | Aiwa CA-DW50 Cassette/CD Boombox
Vo-9800
this sounds like the belts on the take-up pinch wheel if it's streached then it's going to be fast if you can find all belts that take tape to drum and read heads then check each one if streached replace if all fails when replaced belts then it needs repair. hope this works
Aug 15, 2007 | Sony VO-9800 VCR
Voice playback is extremely slow.
try with some contact spray ,put it on the speed of tape button and that will solve the problem for some time.
Oct 30, 2006 | Olympus Pearlcorder T1000 Desktop Cassette...
130 people viewed this question
 Grubhead
Grubhead
