Question about HP LaserJet 1020 Printer
Courier new Prints light, previously on HP Laserjet II P with "draft" printed ok. Original program Wordperfect 6 Current Program Wordperfect 9
  • 88 Answers
Increase the dpi in printing options in word perfect9 300 to 600
Bye
Take Care
Posted on Apr 18, 2008
I am printing documents to my HP LaserJet 5000n Printer and the printer's not responding. I've tried restarting it and it displays that it's processing a job before displays that it's ready.
Either a corrupted driver or possibly a bad network card or parallel port, depending on how you have it connected. Does the printer print test pages from the on printer control panel ok? If yes, try printing a different document from a different program or try the windows test print from the driver. If it prints the windows test print then likely you have either a corrupted program or file. If it will not print the windows test print then I would delete the driver, download the current HP UPD driver and install that.
Sep 24, 2015 | HP LaserJet 5000n Printer
Suddent my sharp arm 257 prints landscape, in wordperfect only. Other programs print properly in portrait. My HP prints ok in all programs.
Check how your printer is set up in wordperfect, it is a software setting problem not a printer problem. You may have to re-instalall wordperfect but I hope not.
Nov 04, 2014 | Sharp AR-M257 Laser Printer Toner...
Error 49.4c18 laserjet3800dn
49.XXXXX ERROR A critical firmware error has occurred.
1. Turn the printer off and then on.
2. Try printing a job from a different program. If the job prints, try printing a different file from the original program. If the message appears only with a certain program or print job, contact the software vendor for assistance.
3. If the message persists with different programs and print jobs, disconnect all of the printer cables that connect to the network or the computer.
4. Turn the printer off.
5. Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
6. Remove the printer EIO card.
7. Turn the printer on.
8. If the error does not persist, install each DIMM and EIO device one at a time. Turn the printer off and then on again after installing each device.
9. Replace DIMMs and EIO devices as necessary.
10. Reconnect all of the printer cables.
11. If the error persists, replace the firmware DIMM.
12. Replace the formatter and calibrate the printer.
Jul 20, 2011 | HP LaserJet 3800 Printer
Can not find a way to print in draft mode so toner
Laser printer can sometimes be set via the front panel on the printer for draft mode. Also, you might be able to set Draft Mode from the printer properties menu in the print driver.
The actual easiest way is change your font to something like Courier, 10P, which is a fixed spaced font.
When the document is finished, then you can do a "Ctrl A" and change the font to a more fancy font.
Don
Feb 18, 2010 | HP LaserJet 3600n Printer
49.4C02 service erreur
Try this
lower slot J1).
necessary.
firmware DIMM.
the printer.
Mar 30, 2009 | HP LaserJet 3800dtn Printer
Why does my new HP Laserjet 1020 12A cartridge print too light?
It's rare that an original HP would do that? It's more likely that it's a compatible / remanufactured cartridge. is it? Compatibles can be as good as or better than OEM (mine are for example), but there are a lot of "hacks" out there.
Either way, I would return it for a new one, because that is your problem.
*please rate me :)
Mar 25, 2009 | HP DeskJet F380 All-In-One Printer
HP 4050N drops pages when printing from WP4.2 under WIN98se
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 12, 2009 | HP LaserJet 4050 Printer
Epson LX-300+II not printing in draft 10 cpi using visual studio .net
use courier font. it works just as draft font. no problem in VB-6 i hope it will also work with .Net as well.
tell if dont work.
asad khan
justasad@hotmail.com
Oct 27, 2008 | Epson LX-300 Matrix Printer
HP LaserJet 2420 Printing trouble
I think that Odyssey user is right it maybe that the print driver is not compatible with the program you are using goto hp.com or hp.co.uk and download the PCL 5e driver
Hope this helps you
Thanks J
Jan 03, 2008 | HP LaserJet 2420 Printer
Continues printing pages
sound like u have setting problem with either the program your printing from or the driver. It could be set to print 2 copies of print job. If your using windows XP there a printer driver in there for the printer. If your using an older version of windows you can used HP laserjet II driver. HP always made there printers to be able to print with LJ II driver.
Sep 25, 2007 | HP LaserJet 6L Printer
HP LaserJet 1020 Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
