It sounds like you need to reset your local zip code to 99999 then unplug the TV for at least 12 hours. Then plug it back in, reset to your real local zip code and go through the guide setup menus.
I can give you these. You should try them until one works hopefully. 0506, 0311, 0612, 0002, 0428, 0802, 0412, 0619. Sometime the universal remotes will not operate everything so be sure to try the power on/off and the volume and try changing channels before assuming the code is wrong. One of these should work...
I had the same problem and unfortunately you will need to replace the tv remote. It costs 24.26 on the panasonic website which is panasonic.com under the parts and accesories section. By the way I know how much it costs because I took the liberty of looking it up for you. Hope the info helps GOD Bless You.
I recently bought a used LCT2060 that had no remote. I figured my
comcast cable remote would work without a problem but it didn't. So 3
universal remotes later I found my solution...a radio shack
universal gamer remote. It controls up to 5 components plus your
xbox360, playstation and pc. The price on sale was a mere 12.97, not bad
if you ask me. Hope this helped. The code that worked for the Akai
was 11676. Take care...
I had this problem on a symphonic 27 inch TV I just bought from a friend
who no longer had a remote. The thing with the menu and buttons on the
front of the TV doesn't actually change the TV to true game mode. I
don't know what it acutally does, but it isn't really in game mode.
When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone
told me about) for 8 bucks at walmart and I was then able to switch to
game mode with the Input select on the remote. The remote I bought that
actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629 Make
sure you look at it before you buy it and make sure it has a button
that specifically says "input" on it. I know that some of the universal
remotes don't have an input select button or one that doesn't work. As
long as you get a Philips-Magnavox that has that button, you should be
ok. Much better solution that paying 30 bucks for a new remote
specifically for the TV. Hope this helps.
I'm sure you know you need the original remote if there is no menu on the front of the set. I suggest doing a search for customer support online for Sanyo products. There you will find contact numbers to see if one is available. Try "Sanyo remotes" on Google or Yahoo etc. Hope this helps
There are some codes for Viewsonic tv's but apparently it's really hard to program and the codes even change. I read somewhere once that the best way to program it is to try with those really expensive remotes that can program everything, but you will need to contact viewsonic for the software to upload to that remote.
