Question about M-Audio MicroTrack 24/96
Freezes while recording
Sometimes, when I have the micro track in recording mode it freezes.  This tends to happen after it's been in recording mode for 15 minutes or more.  I don't have the problem on shorter recordings.  The screen will read that it's recording (showing the round dot in the upper left hand corner) but meters are not moving.  When I press the red recording button to stop recording there is no response.  The round dot does not change to a square.  The menu button does not respond.  I cannot get rid of the "recording" screen unless I press the power button which turns off the whole machine, and, of course, I lose the file that I was recording.  I have been recording in the mp3 format, so I always have plenty of recording time left when this freezing problem occurs.  Any suggestions?  Thanks-- sharmanduran@hotmail.com
  • 1 more comment
  • dee_white Jun 05, 2008
    I have the exact same problem...I have just tried a recording three times and it froze at 7, 2 and 22 minutes. I updated the firmware (again), but I'm not convinced this will fix the problem as I've done this before and the problem returned.
  • seanap Feb 26, 2009
  • wwwebber Apr 26, 2009
    During recording - yes usually during an extended session - device locks in the middle of record screen. No level activity and no response to any controls. Have to shut and restart, losing my file. Then I can resume, but after losing much of the session. Not acceptable. If I can't find a positive solution, I'll have to find another device for my needs.
  • 3 Answers
I'm been searching for slutions to this as well - It's happened to me numerous times, so much so, I've almost thrown it on the ground to see how many pieces I can break it into...
Posted on Sep 04, 2008
  • ArcadianZ Sep 04, 2008
    Ok, so I'm signed-up as a "solution provider" -oops
    Well, then I'll offer this: use ONLY the memory card types/brands that M-Audio has certified.
BR-1180 freezing & high-pitch ring
Check your power supply to the unit. Low voltage COULD cause this.
Also make sure a setting is not "looping" the audio back into itself.
May 23, 2010 | Boss Micro BR Digital Recorder
What are the exact steps to bounce tracks on the Boss Micro BR
It’s necessary to bounce all of your tracks to a stereo pair of tracks before you can export your song to a computer as a WAV or MP3 file for burning onto a CD.
1. In normal mode, push EXIT and UTILITY until you see BOUNCE on the display.
Note: The upper right corner of the display shows the track you’re bouncing to. By default, “12V2”—Tracks 1 and 2, Virtual Track 2—is selected.
2. Press STOP and REWIND together to go back to the beginning of the song.
3. Press RECORD, and then press PLAY.
4.When the song’s finished playing, press STOP.
i read some stuff online and this should help.
Apr 15, 2010 | Boss Micro BR Digital Recorder
I want to know how to track c.d. when recording,I don't have a remote??
If you mean you don't know how to manually mark a track in Manual Mode >>while<< recording on the fly:
Toggle the Auto/Manual button to Manual
Press the SKIP/Search right arrow button for tray B while recording whenever you want to increment the track number.
Pausing or stopping the recording also increments the next track number. There is no way to manipulate the actual number assigned to any track. It is alway PLUS 1 from the last track.
I always use Manual track numbering on my Pioneer machine when recording analog sources because many machines (like yours) will interpret a short silence as a track break. This may not necessarily be what you want to happen.
Feb 24, 2010 | RCA CDRW120 2-Disc CD Recorder
Boss micro br not converting all the tracks in the song to MP3
You have to "mix" the tracks to create a final work before saving the file.
Jan 31, 2010 | Boss Micro BR Digital Recorder
I recorded music on track 3 and a voice on track 4 but when ever I try to record to CD disk I only get music and no singing
You have to bounce your tracks to a sstereo pair of tracks. Have a look at this document:http://cms.rolandus.com/assets/media/pdf/MICRO_BR_Q_A.pdf I hope this helps.
Nov 26, 2009 | Boss Micro BR Digital Recorder
It keeps locking up
I had a similar problem before mine completely crashed. Make sure you back up your data and have a look at the space you have left on each of your three partitions. Try to delete any unused track space before recording again.
Nov 17, 2009 | Tascam 2488 Portastudio Multitrack...
I need help with my Boss Micro BR. I want to convert the song I recorded to MP3, so that I can hear it on my laptop. I connect the recorder with the laptop through U.S.B. and can only get to the files that...
Go to bossbr.net - Plenty of answers there! And yes, you have to master or export the tracks to .mp3 or .wav. These files will be located in the mp3 folder. Boss also makes a free .wav converter located on their website.
Oct 05, 2009 | Boss Micro BR Digital Recorder
When bounce tracks on my micro-br there seems static going on
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
Sep 27, 2009 | Boss Micro BR Digital Recorder
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
M-Audio MicroTrack 24/96 Logo
402 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
