Question about Toshiba IK-WB01A Network Camera
Need to change ip address for my camera
I installed a new cable modem and a new router. Now I have a new IP address on my WinXP PC. The problem is that my camera stopped working. It appears that it is now on a different subnet. my new IP address ends in 1.1 and my webcam ends in 0.99. I need to change it to 1.99 but everytime I try to get into the camera settings by typing in the ip in the browser it comes up with "page cannot be displayed".
  • Anonymous Oct 09, 2008
    need my ip addres how can i to change?
    Sergeant:
  • 221 Answers
How is your webcam connected to your network? Is it connected to your PC or your router?
If it is connected to your router, go into the router settings and see if the router reassigned a new ip address to the camera. If you set the router up for DHCP, it will automatically assign IP addresses to all devices that are connected to it, as long as the individual devices are also set to dynamic IP addressing. Your router is set up for the 1.0 network, so your pc is most likely 1.2, while your router port connecting to your home network is 1.1.
Another thing you can do is make sure your webcam is turned on and go into 'My Network Places', then click on workgroup computers. See if the webcam is listed there.
Posted on Apr 11, 2008
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
No connection
Ok here is what you do
1.) disconnect your internet cable
2.) connect your router to your computer
3.) in internet explorer type 192.168.1.1
4.) enter your username and password
5.) click on Lan
6.) In the ip address box change your router ip to a new ip
e.g. 192.168.1.2
7.) Click on DHCP AND ENABLE THE DHCP SERVER
8.) Click on wan
9.) In Wan settings choose static ip address
10.) set the static ipaddress to the ipaddress you entered for your router
11.) set your subnet mask
12.) In the isp gateway enter your modem ip e.g 192.168.0.1
13.) as your primary dns enter your modem ip e,g 192.168.0.1
14 save changes and exit
YOU CAN HAVE THE ROUTER AUTOMATICALLY ASSIGN AN IP ADDRESS TO EACH SYSTEM OR YOU CAN SET IT AUTOMATICALLY
FOR AUTOMATIC ASSIGN JUST CONNECT THE CABKLE
FOR STATIC IP(recommended)
double click on the network icon to the buttom of your screen e.g LOCAL AREA CONNECTION
Click on Properties
Double Click on Internet Protocol(TCP/IP)
Enter the ip address you want the computer to have using the same 3 bloacks as your router e.g 192.168.1.10
Enter your sub net mask
Enter the ip for your moden in defaul gateway e.g 192.168.1.1
Enter the Prefered Dns as also your Modem ip 192.268.1.1
cheers
Jan 05, 2008 | Linksys Wireless-G WRT54G Router
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
I have no internet connection when i connect my adsl router with enhwi g2 router in WAN, then from lan1 connect my pc. Please solve my problem. Tnx
First test to see that you can connect to the Internet by connecting directly to the modem.
If yes, then check that the cables are connected correctly and that the LEDs are on. (Just a check :). Telephone line to LINE IN on modem then Ethernet/Cat 5 from LAN port on modem to WAN port on Encore router, then Ethernet/Cat 5 cable from LAN port on router to PC.)
Use browser (Internet Explorer, Safari, Mozilla) to connect to web interface of router (make sure your TCP/IP settings on PC are set to obtain IP address using DHCP).
Open browser and type in the IP Address of the router (192.168.1.1 is the default) where you usually type in the name of the website you want to go.
Go to the LAN Interface Setup page (you are now inside your router).
Change the IP Address from 192.168.1.1 to 192.168.89.1 (leave the subnet mask as it is).
Change the DHCP Client Range from 192.168.1.100 - 192.168.1.200 (the default) to 192.168.89.100 - 192.168.89.200.
Click on Apply Changes button.You may lose connectivity to the router, but you can reconnect by typing in the new IP Address 192.168.89.1. You may need to renew the IP address of the PC, but that can be easily done by rebooting the system if it doesn't happen automatically.
Let me know how you go, or leave a message if you still can't connect. I would ask that you tell me the model of the ADSL modem however.
Cheers
Dec 17, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
I have a Belkin N-Router and I was wondering how to connect it to my modem because the cable it has connects only to where the modem's ethernet cable is located when i just run my modem, and there is only...
plug the one ethernet cable from the modem into the router wan port . The modem will have an ip address note this and then change the ip address to one higher than the modem for the router's ip address and change the ip address in the router to make the gateway ip address the modem ip address.
Disable the DHCP server in the Router iIf the modem has an active DHCP server in the router.
Plug the rest of your network into the other router ethernet ports.
Feb 24, 2018 | Toshiba DOCSIS Cable PCX2500...
I am trying to install a Netgear WGR614v9 router. Disk will not install it, so tried a manual install. Shut down all firewalls, used no passwords or security settings. It keeps throwing me back to the...
The router needs to be configured manually. Follow the steps below.
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing). Or password is admin also.
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing). Or password is admin as well.
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Oct 06, 2009 | NetGear WGR614 Wireless Router
Change ip
Your IP address is assigned (leased) to you from your internet service provider. With that being said, you could possibly call them and ask to release your old IP address and have them assign a new one. If you happen to have a static IP address assigned from your ISP you can call them as well and ask to have your IP address changed too. It would be up to them to change it though.
Sep 14, 2008 | 2wire (1000-400108-001) Router
PLease Help
The router should get the IP address on it's own when connected to a DSL or cable modem. If it's needing an IP address then it should be from the modem. The router can have an issue if the modem and router use the same IP range. Try changing router to 192.168.2.1. This can stop the possible conflict for why it's not getting info on it's own.
Aug 20, 2008 | NetGear WGR614 Wireless Router
Connection
Yes I have a suggestion, here is what you need to do.
1 Make sure your new router is connected to the Ethernet port on the DSL/Cable Modem, you never specified which type of modem you have, if I knew this information I could assist you even more accurately. Your PC should be connected to the new router also on one of the Ehternet ports, they usually have 4. You need to verify your computer (PC) is getting the DHCP information from the new Router(Linksys) This can easily be determined using this command in az DOS window. If you are using Windows XP, again you did not specify your PC's OS, go to "Start", then "Run" and type in "cmd", withouth the quotes.
This will open a DOS window. In this window type "ipconfig /all"
The important thing to look for here is your Network cards IP Address, Default Gateway, Primary and Secondary Domain Servers Addresses. These should nearly match your daughters information, except for the IP address, whcih will be close but the last number(s) will be different. Most of the time the problem is due to both the modem and the router are on the same network and are both running DHCP, which is what gives out the IP address, default gateway and DNS information for your PC and your Daughters to use for Internet access. It could also be that your PC has the same IP address as her's, whcih will cause the exact problem you are discribing as well. If you turn off her laptop and can then access the Internet on your PC, then this is exactly what is happening. You will then need to make sure the Linksys Router and the DSL/Cable Modem are on a different network, by changing the address of one or the other, it is easiest for you to probably just change the Router. It is problably set to 192.168.1.1 or 192.168.0.1 Hook your PC directly into the modem again. run the command "ipconfig /all" and look at the IP address it gives your PC. If this is the same as the one your Router is giving, then you have found your problem. Unplug from the modem an again plug straight into the router, nothing else. Open a web browser and type in http://192.168.x.x whatever the IP address is for the default gateway that is shown on your PC. You should get a login window. By default Linksys usually uses admin as the username and password, consult your manual to be certain. In the web page that opens, your manual can help you further here as well, there should be a "Setup" link you can click where you can change the "LAN" network IP Address. You only need to change the 3rd number, as in 192.168."X".1 If the modem was 192.168.1.0 for example change the Routher to 192.168.2.0 and you should be fine. Please let me know if this has helped or if you need further assistance.
Jan 05, 2008 | Linksys Wireless-G Broadband Router
Installation problem with edimax 6104kp
Hi Omdi,
Please proceed with the following instruction as follow.
1.) Connect first the modem to your pc, if you find it is working then get the IP Address, Subnet, Gateway, Primary DNS, Alternative DNS at the network properties TCP/IP.
2.) Open your router where you can configure the static IP or manually enter the IP address, subnet, gateway, primary dns, alternative dns.
3.) Make it sure you used the cable properly by connecting it to the appropriate line. For the modem to router you should connect the cable to WAN port. And the LAN port must be go through the computer.
If you still experience the problem, please let me know.
Best regards,
Philip
Oct 02, 2007 | Edimax BR-6104K Router (br6104k)
Toshiba IK-WB01A Network Camera Logo
4,676 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
