Question about Toshiba 62HM195 62" HDTV
No Picture Hello, I have sound but no picture, what do you think?
  • jlyarrow May 24, 2008
    Same problem only with over-the-air HD signals. Over-the-air analog is fine. Fiber-optic digital signal is fine. Just no picture but sound on HD.
  • smartchic Jun 10, 2008
    i have a 62" toshiba and all of a sudden it turned off. i turn it back on i get sound but no picture after a couple seconds the green light begins to flash and it turns off then the red light comes back on and the tv turns itself on. what do i do?
Need to replace the lamp. There is a little yellow light that will come on on the front of the set to confirm
Posted on May 29, 2008
Hey there just have simple question: Is it possible to lock setting for the different modes? I have found that a little brighter for movies and games works for me but I think that it keeps switching back...
Hello
Just enter to its picture and sound settings by menu option, and do the picture setting as you interested in.
1 Press MENU on the remote control.
2 Use Up, Down, Forward, Reverse buttons to select [ Setup] > [ Picture].
3 Use Up, Down, Forward, Reverse buttons to select one of the picture settings, and press OK
to enter the setting.
4 Adjust the picture quality.
The following picture settings can be confi gured. Depending on
the format of the picture source, some picture settings are not
available
You must set [Home] in [ Location] Otherwise, the settings you adjusted will not be memorized after you
turn off the unit.
You can set the location of your TV to [Home] or [Retail store].
Choosing [Home] gives you full fl exibility to change predefi ned settings for
picture and sound.
1 Press MENU on the remote control and then use Up, Down, Forward, Reverse buttons to
select [Setup] > [Installation] > [Preferences] > [Location].
2 Select [Home] and then press OK to confi rm your choice.
3 Press MENU to exit.
Mar 23, 2011 | Philips 55PFL7705D 55" LCD TV
Some channels have lost their sound. picture is ok, but no sound. this is rcab27tf680
Hello; I am John at J. D. Electronics, Poland Maine. This problem is very likely caused by SAP selected on your remote control. Make sure you have selected Stereo or Mono in the audio menu. You can find all of this in your owners manual ( which you can probably download if you don't have it). Good luck, John
Nov 22, 2010 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Buzzing sound + Tv picture is very weird.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS.. AND ALSO ALL FUSES AROUND IT .THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE.
GOOD LUCK
May 23, 2010 | Polaroid TLA-01911C TV
Hello. We received a SmartParts digital picture frame Model SP800W and it doesn't turn on even with the AC power cord plugged in the wall. There is no sound coming from the frame ( sounded like there was...
Probably more than it's worth! Many of these items were found to be defective when shipped. This is the 41st one of these I have heard about with the same problem.
If you can return it for a refund or swap for another brand.
Please rate my help++++Thanks for using FIXYSA
May 22, 2010 | SmartParts (1DPFSP01) Digital Picture...
Tv has sound but no picture
the problem is from your picture IC. The picture IC of your TV is faulty and need to be changed/replaced for your TV picture to display again.
Good luck.
Mar 11, 2010 | Televison & Video
Hello, LCD Problem. I have sound but no image. Black screen. No access to the configuration menu. Someone can help me ??
I think your LCD TV lost back light that is why you have sound but no picture to see it as LCD TV requires back light to present picture on its screen.
Please intimate model and brand of your LCD TV to provide you more info.
Sep 17, 2009 | Televison & Video
Hello sir,
Your tv needed to program the reset. fixable, just call me at 323-767-6030 and I will go through with you.
Sep 12, 2008 | Astar LTV-20SD 20 in. EDTV-Ready LCD...
Picture is gone! :*(
the picture tube (what makes the TV picture work) has blown out. Just call you nearest tv reapair shop and purchase a new one. (these are kind of expensive!)
(Also, if it's fifteen years old, i think it's time to get a new T.V. hint. hint.)
Jul 03, 2008 | Zenith C27A24T 27" TV
My RCA 20F510TD 20 in. has sound but no picture
May need a horizontal driver transformer. Rca can not provide a part number. In the future don't buy this junk from China.
Jun 22, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
May 23, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Toshiba 62HM195 62" HDTV Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
