Question about ASUS P4S800-MX Motherboard
Power switch wire.
I am putting a new mother board in my pc and i would like to know where to put the power sw connector. I have tried ever connector so far and the power is still not coming on?
    Genius:
  • 1,027 Answers
Page 14 of the users manual
Posted on Apr 11, 2008
    President:
  • 2,351 Answers
In you're manual pg. 1-23 you'll find this.
Power switch wire. - c81857d.jpg Don't have you're manual download it here.
http://support.asus.com/download/download.aspx?modelname=P4S800-MX&SLanguage=en-us
Mike
Gateway Desktop GM5626: Would not power-up, replaced Power Supply; Then Mother Board beep once when trying to turn-on; replaced Mother Board; Mother Board lights on, but when I try to turn on the CPU...
some powersuplay comes with 2 extra connectors a 4pin based switch connector and a alternate power supply for the fan...you must to be sure if it is comatible......check the model and search on google for compatibility ...
May 31, 2011 | Computers & Internet
My compaq presario sr2010nx desktop won't turn on. I tried fooling with the off/on switch wiring and it came on for a short time. All was well. I hadn't used it for a week and tried to turn it...
Hi.
Sounds more like a power supply problem. First test the on/off switch by tracing the wires to where it connects to the mother board. The plug is usually marked "pwr sw" . Unplug the wire from the board & short out the 2 pins where the switch was plugged in using a small screw driver or any other conductive material. If the pc still fails to turn on, try replacing the power supply.
Best wishes,
Graemevm
May 10, 2011 | HP Compaq Presario SR2010NX PC Desktop
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the...
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Nov 25, 2009 | E-Machines eMachines Desktop PC
Motherboard wire hook up I pulled the wires : Power LED, Power SW, H.D.D. LED off the motherboard, don't know the pattern to put them back on.
its simple, start from left power led next to power led is power switch, just below power switch put hdd and next to hdd put reset . thats it done.. all boards have the same module.....
Nov 24, 2009 | Computers & Internet
Need picture of mother board for Emachine C2825
I've built a PC myself, each connector had text on it to say what it was and one arrow on it in relief, don't know wether that indicated plus or minus anymore.
Anyway, I recommend you just plug them in, and try to boot the PC. If it doesn't boot, switch the Power SW connector around, then it should boot. Do the same with the LED connectors, and it should work just fine!
Good luck,
Yannick.
Jul 13, 2009 | Intel D845GVSR Motherboard
I need to know what colored wires go where on my customers PC hdd led/ power sw/ and power led
the only reason to have removed them was to switch the board or put the board in a new case..if you put a new board the new board is what you have to go by, look in the book, or take the number off the motherboard and go to yahoo and type in schematic for xxxxx board.
DO NOT go by emachine model as its worthless, too many models have different hardware.
This is all basic repair 101, how do you have customers? lol
Apr 24, 2009 | E-Machines W4685 PC Desktop
Wire came loose on pavilion xe 734 that supplie power to hard dir
First of all these wires don't supply power to HDD. These wires are for indicator LEDs on the front
panel of the cabinet. One wire `power sw' is to switch on the system from the power button on front panel. `power led' wire is of the power led on the front panel. All these wires will be connected to the cluster of pins on one corner of the mother board. If you can see it will be indicated & printed near the cluster of pins on the mbd, that which pair of pins is meant for what connector. Try to correlate the names on connector with the print on the mbd.
Jan 06, 2009 | HP Computers & Internet
Pwer led,resetsw,hdd led,pwer sw
It appears your board is made by Jetway.
Heres your link for the manual:-
http://www.jetway.com.tw/jw/downloadshow.asp?productid=V266B#
You can also download drivers et,c. from the same site.
Please don,t forget to rate the Post.
Best wishes mike @Compurepair
Mar 29, 2008 | Intel Motherboard
NEED TO KNOW WIRING
i have been to fic's web site, i cannot find any mb labeled au31.
do you have anymore information about the board, how old, which processor, what socket, which north bridge, south bridge, which model system, etc?
however the pins are usually marked "pwr sw" or "pwr" and are usually with all the other front panel connector pins.
Oct 17, 2007 | E-Machines eMachines Desktop PC
New Problem
The manual you need will be on the board manufacturers web page, howevr I will bet you have the case power switch and perhaps the reset switch on the wrong pins on the mother board. To check this, remove the switch leads from the mother board, then use a small screw driver and bridge the pins on the mother board a pair at a time. All of these leads plug on to the board in a line and not across the two lines of pins. when you get the mother board to fire up by this method geet a torch and look closely alongside the pins you will see the letters PWR SW or RS SW. It does not matter what polarity these two sets of leads are plugged onto both will work. The LED lights on the case front will only work if the polarity is correct but it will not do any harm if they are backwords. On the board you should se two sets of pins marked HDD and PWR these are the led light pins you will know you have them right when the usual red and green lights are working at the front of your tower. Regards mistyman
Aug 15, 2007 | Balance CP4401 PC Desktop
ASUS P4S800-MX Motherboard Logo
662 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
