Question about HP PSC 2175 All-In-One InkJet Printer
Speed and Cleanliness
It used to print much faster, now it prints very slow and I can't figure out how to clean under the glass.
    Novelist:
  • 79 Answers
You can follow the following steps to clean the spooler on your computer that might speed up the printing speed .
  1. Open a Command Prompt window >
key the command net stop spooler
2. In the run (Start Search for Vista) type : c:/windows/system32/spool/drivers…look for w32x86 folder.
3. Inside w32x86, there will be folders with the names 2 and 3 delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves. Inside 32x86, there may be other folders with names starting with "Hewlett-Packard", "hphp" or something else; delete these folders also.
4. In the run
type : c:/windows/system32/spool/printers: delete any files there.
5. Open a Command Prompt window
key the commands
1. sc config spooler depend= RPCSS
(note the space after the = but not before)
2. net start spooler
Cleaning from Registry:
1. Take backup of registry:
2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
  1. There might be two entries names Version-2 and Version-3 under drivers: click the plus sign against them and remove everything under them.
  2. Then click the plus sign against PRINT PROCESSOR, which is under DRIVERS and make sure there is only one entry i.e., WINPRINT. If there is any other entry, just remove it.
The spooler cleaning is complete
Posted on May 30, 2008
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
I am simply making a copy and it is printing super slow.
hELLO IDEAL58ST,
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. SOLUTION: Solution After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model.
THANKS.
Sep 06, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Print slow
Ink jets print slower than other printers. I have used many printers and found that if your documents are black and white only the print is faster. The font also makes a difference. if the font is fancy it takes longer for the printer to translate.
Apr 25, 2010 | Brother MFC 420CN All-In-One InkJet...
Printing is really slow almost 10 mins to print i am using Vista and have had updated the driver for vista but still
Epson R230 print slow at PHOTO, very slow at BEST PHOTO, if you do not need photo quality prints try printng at TEXT AND IMAGE for faster printing and the quality is still good. Also try to lower the resolution of that you are about to print, high the resoluton images takes longer time to print. Hope this will help you, Good luck!
Oct 14, 2009 | Epson STYLUS R230 InkJet Photo Printer
Copying is extremely slow but printing speed is fine
press the menu button, and then the copy option, under that you will find copy speed , see if that resolve your issue
Aug 17, 2009 | HP Photosmart 2610 All-In-One InkJet...
Not having good quality print with zebra z4 m
Try slowing down the print speed to 2 ips. Then increase the speed. Usually, this is a problem of exceeding the limits of the printer. The faster you print, the weaker the print. With a ribbon that is matched to the label stock, you will have an optimum speed for best performance.
May 22, 2009 | Zebra Z4M Printer
Cannon Pixma MX310 prints too slow.is there a way to print faster
Go to file menu, select print, and then click properties within the program that you are trying to printer from. There should be speed/quality settings here. It really depends on your printers drivers. But the high the print speed the lower the print quality. Other than that there is no way to have a faster printer without sacrificing quality except to buy a new printer. Laser printers are by far the fastest printers.
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Slow printing
Even though the printer doesn't call for new ink, remove or replace the color cartridge. First I removed the color and the test page printed at full speed. I then put in a new color cartridge and it again worked full speed. I believe the problem was somewhere in the half used color cartridge. Hope this solves your problem.
Jan 26, 2009 | HP PhotoSmart 7760 InkJet Printer
HP CLJET 3700 SLOW PRINTING
Tried what TRANSCORP99 said, can't quickly determine how to reach and clean media sensor. Try this...worked for me...
On the printer...go to Menu
Jun 04, 2008 | HP Color LaserJet 3500 Printer
Printing Slow
hi,
check the length of the usb cable. if it is very lengthy then there would be problems with the speed.
if not
> unplug the usb cable
> click "start-->control panel--> printers and faxes"
> select the printer icon and delete it
> restart the computer
> plug the usb cable
> wait for few minutes while the driver installations are complete automatically.
> once that is done, try to print
thanks and regards
agnel
Mar 08, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 2175 All-In-One InkJet Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
