Question about Canon PowerShot S2 IS Digital Camera
Camera won't turn on
Batteries are fresh.  Power light blinks and clicking noise inside camera which stops after about 30 seconds.  Screen goes black. No power at all.
  • 104 Answers
Sir, use 2100mah rechargable batt
Posted on Apr 11, 2008
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
My camera just stopped working. when i turn it on the lense open slightly and the lense wont come out as usual and the light shows for 5 seconds blinking then goes off. the model of my camera is a BENQ DC...
Your batteries have worn out. They don't give enough power for the camera to switch on properly.
Replace the batteries. Use 1000mAh or better batteries.
Aug 21, 2011 | BenQ DC X610 Digital Camera
Screen blinks for one second when switched to camera mode and than is black. Len's comes out but camera won't work. Card is installed and batteries are new.
screen blinks for one second when switched to camera mode and than is black. Len\'s comes out but camera won\'t work. Card is installed and batteries are new
Feb 20, 2011 | Fuji FinePix F420 Digital Camera
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Kodak DC 260 The camera does not turn on. For some seconds the power light blinks green, then it changes to blinking red and the diplay shows ''E 11''. Then it turns off.
It could be something more serious, or as simple as inserting fresh/fully charged batteries, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Sep 01, 2009 | Kodak DC265 Zoom Digital Camera
Sony Bravia 40 inches has a defect
More then likely your power supply failed. If you do not hear a click from the relay during the power up cycle then your power supply failed.
Jul 29, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Power Problem
Same problem as sweetpetny...blinking power button, won't on.
Jul 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Monitor goes black
It always does that while it's powering up the flash again. If you're saying it doesn't come back after a few more seconds, that is a problem. Or maybe by that time, the power saver kicks in. You can tell if the power light starts blinking. Then you just have to press the shutter button again to turn it back on.
Aug 20, 2007 | Nikon COOLPIX L5 Digital Camera
Camera switches itself off seconds after turning it on
This is a service center job and I think the lens assy motor is jammed. Take to a near by camera repair center
Feb 04, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
